![]() | #1 |
Newbie Join Date: Nov 2006 Location: Fairfield, CA
GD600 w/55turn blew my tranny. Any suggestions for an upgrade?
![]() | #2 |
MODERHATER™ ![]() Join Date: Nov 2005 Location: Colorado
Nice I know my tranny has been running for years with no issue-GD and a 55 turn. What kind of voltage are you running? More info? |
![]() | #3 |
Voltage? Its a 3000 Bat charged with a superbrain. It may have been the fact that my 2 yr old nephew wedged it between to bolders and poored the coal to it. I guess i'll have to restrict him to the nylint again
![]() | #4 |
Rock Crawler Join Date: Sep 2007 Location: Denmark
Swab to a maxx gearbox = hi + low ![]() my 2c |
![]() | #5 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
put moab xl's on it. then instead of $10 gearsets you can break $10 axles. at least teh axles are easier to get to.
![]() | #6 |
Quarry Creeper Join Date: Nov 2004 Location: Fenton, MO
If you got the cash get a tranny from rc4wd and never worry about it again. Maxx trannies are sloppy for a crawler.
![]() | #7 |
Powered by Awesome ![]() Join Date: Sep 2004 Location: Parker, Colorado
well.. ive bashed my txt trannies like none other and never done that.. same setup.. txt tranny with a gd600 and a 55 turn... honestly.. i ran a 27 turn stock can for the longerst time and it had more then enough grunt to move her around. The upside of the 27 turn can is that when she got bound up, it didnt have enough grunt to break anything.. but with the 55 turn.. something somewhere has to go... so.. theres you answer... if he wants to drive it, swap in one of the stock can motors first.. on my stock can i was running a 9 tooth pinion. |
![]() | #8 |
To be fair, I'm running 2 55t integy's through dual gd-600's. that is how I bought the thing as someone elses used project. I never bothered to count teeth. I did get to rebuild my tranny though. the new gears are still holding up through two snapped axles.
![]() | #9 |
Quarry Creeper Join Date: Jan 2007 Location: I live in my own world,they know me here
If you need a txt tranny let me know,I gotta clean house a little bit.I use a 'Pede tranny for mine,works great.
![]() | #10 |
Pebble Pounder Join Date: Jan 2006 Location: Calgary Alberta Canada
Sorry for the thread jack but Red Jim what setup do you run with your pede (motor, voltage, extra gear reduction, and spur and pinion) If you could let me know that would be awsome. Thanks. |
![]() | #11 |
Mamba Max,Hyperion Z 3025-8 motor,GD600 with 2.5:1 reduction and a 10/87 combo on the 'pede.I am currently running 9.6 volts but will be going to 11.1 soon.
![]() | #12 |
Sweet thanks alot I will give a similar setup a try with my goat. Thanks. |
