01-26-2008, 07:41 PM | #21 | |
Newbie Join Date: Nov 2007 Location: North of US
That's a good setup but I'm trying to get down to under 11". The WK stubs (5.00 per pair) will fit with if I mill the groove out for the TXT pin. Then all I need to do is mill up some custom C' to get them on there. Last edited by Parker; 01-26-2008 at 07:44 PM. | |
03-15-2008, 12:46 AM | #22 |
i got my front axle done, and my tranny adapters, process is slow due to building turbo Yamaha's right now. |
03-15-2008, 02:54 AM | #23 |
ΜΟΛΩΝ ΛΑΒΕ Join Date: Dec 2006 Location: In tha Bush of Louisiana
Looks very nice the axles sure have some beef on the ends |
03-15-2008, 11:59 AM | #24 |
That turned out really well! Good job. What is the width (hex to hex)?? |
03-15-2008, 01:31 PM | #25 | |
9 1/4 hex to hex but with the smaller C's & knuckles I can get positive offset wheels from Mayham or VF to bring her in some more. I have to start milling the rear straight axle adapters now. I've got the pieces to make the jig and 20 feet of 1/4 tube on order is 3.00 a good deal for 20 feet of tube? Thanks Last edited by Parker; 03-15-2008 at 01:34 PM. | |
03-17-2008, 05:39 PM | #26 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
Parker what and where did you get that tranny? You say thats a 2 speed?
03-18-2008, 09:43 AM | #27 | |
It runs super slow, and super fast, but it is super heavy. Last edited by Parker; 03-18-2008 at 09:45 AM. | |
12-11-2008, 10:57 PM | #28 |
| Suspension idea
Been a little busy but have made a little progress. any comments on this suspension setup would be appreciated. Its a droop setup with a cantilever shock shared front to back, so as the front goes up the back gets pushed down. |
12-11-2008, 11:01 PM | #29 |
Here is what it looks like stroked. |
12-11-2008, 11:05 PM | #30 |
Here it is full droop in the front. |
12-12-2008, 06:52 PM | #31 |
Pebble Pounder Join Date: Jul 2007 Location: Planet Earth
I'm diggin the suspension design. I had a similar set-up on my TLT-1 basher, I used aluminum LST2 bellcranks for the cantilevers. However all you really need is the center shock, why not just replace the front and rear ones with some solid links. I like the machine work on those axles though.
12-13-2008, 09:57 PM | #32 |
You'd need a solid link on top instead of the shock, to make it work that way, or else the upper shock would just compress instead of pushing/pulling the other end. Keep up the out of the box thinking, that's how new things come about |
12-14-2008, 02:46 PM | #33 |
I was going to leave the front and rear shocks springless and use a spring on the center, kind of a droop/coupled/sprung setup. Then again I may not as I'm hurting for room on the right rear for shock mounting since I put my motor and trans back there on the axle. Last edited by Parker; 12-14-2008 at 11:57 PM. |
12-14-2008, 11:56 PM | #34 |
12-12-2010, 07:38 PM | #35 |
Pebble Pounder Join Date: Jun 2009 Location: Hudson, NH
Any updates?
