Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Stock flex?
Old 07-21-2004, 09:31 AM   #1
Default Stock flex?
has anyone measured the amount of flex from the stock setup?
I took off the spacer at the end of the shock body and the rubber bump stop and I think I gained about and inch net of overall fex
jeep_boy02 is offline   Reply With Quote
Old 07-21-2004, 09:33 AM   #2
Default Re: Stock flex?
I believe that a bone stock TXT with the sway bars on, will net about 8 inches of upard travel. Eight inches is plenty of travel in rc crawling.
DirkDigler is offline   Reply With Quote
Old 07-21-2004, 01:07 PM   #3
Diggin' the new SCX10 II!
badger's Avatar
Yep, here is a similar thread.
http://www.rccrawler.com/postt300.html
badger is offline   Reply With Quote
Old 07-21-2004, 02:30 PM   #4
i got 75* with out the sway bars and 87* after i changed the link mounts.
skyjacker_rc_club is offline   Reply With Quote
Old 07-21-2004, 04:25 PM   #5
badger's Avatar
I got 120* with bruit force!
Old 07-21-2004, 09:54 PM   #6
nice lol. what did you have to snap for that to work?
Old 07-22-2004, 01:58 AM   #7
I can get my mostly stock TXT to measure out at 10.5" at the bottom of the tire, if you were to lift one tire up until one of the rears just about comes off of the ground.
If you want a visual on what an almost, very close to stock, TXT can do go here:
http://www.rccrawler.com/postt575.html
And yes, I drove my truck into all of the pics....Just ask Grizzly or Dirk!
bustedcrawler is offline   Reply With Quote
Old 07-28-2004, 07:17 PM   #8
I got 90* with no problem but I changed the bar to the top axle. best change I ever did
Herzog-racing is offline   Reply With Quote
