02-23-2008, 03:14 PM | #1 |
Newbie Join Date: Aug 2006 Location: USA
| Gear pitch (module)
Hey, I am working on my TXT axles and as far as I can figure, the gear pitch (for the 28 tooth spool and 16 tooth drive gear) is 1.25 module. The tooth count versus diameter looks correct when I measure them. Does anyone know if that is correct? Oh, I am going from the stock 16/28 tooth setup to a 14/30 tooth setup. That will give me 22% lower gearing with (if I did the math right) the same shaft spacing. Thoughts? |
