Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: fill oil in the axle housing?
Old 05-12-2008, 05:03 PM   #1
Default fill oil in the axle housing?
Hi,
Did any try to fill up oil (motor oil) in the axle housing that enough to be touched by the diff? It will be similar to a real car. It will let he diff gears to lub itself by touching the oil, in theory..... Not sure if it will leak out instantly though......
DDT
MonsterDDT is offline   Reply With Quote
Old 05-12-2008, 06:22 PM   #2
Keep it real
Tanis's Avatar
Just use grease, the case isn't sealed
Tanis is offline   Reply With Quote
Old 05-15-2008, 02:20 PM   #3
I Have tryed it on gearboxes and axles and it didn't work:-( leaked out
been thinking of mixing something up to the viscosity of double cream? "Hmm double cream"
Please note,
one oil i used made the plastic soft and it split! sorry can't remember which make
DeadMeatUK is offline   Reply With Quote
