07-05-2008, 04:32 PM | #1 |
Rock Crawler Join Date: Jul 2008 Location: E. City
| TXT Steering Issues
Hello everybody, new to the forums here but not new to rc. I have a TXT1 and am tired of the stock steering setup. I did a search but couldnt really find what I wanted. I know there is some sort of mod out there to put the servos on the axels or behind the axels. I would like to know how to do this and how much fabricating is involved. If there is another thread on this subject maybe you could direct me toward it. Thanks! |
07-05-2008, 04:37 PM | #2 |
Newbie Join Date: Dec 2006 Location: Seiad Valley
I have a carbon fiber servo mount behind the axle on mine... I believe that it was made by Xreme Carbonfiber, or something like that. If you search on Yahoo for a Juggernaut servo mount you should find them... good luck, nice yellow by the way.
07-05-2008, 05:26 PM | #3 |
Thanks! I did a search and found a carbon fiber servo mount for the clod but there are no pigs of it. Do you have a pic of your setup that I could see? Is the clod setup compatible with the TXT axle?
07-06-2008, 09:18 AM | #4 |
Rock Crawler Join Date: Jan 2007 Location: Lehigh Valley
Try this link Servo mount? |
07-06-2008, 04:15 PM | #5 |
RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
MINE... check your PM |
07-06-2008, 08:11 PM | #6 |
Jeepernick, PM'd you back. Jmz6, I saw that thread after I posted, my search did not find that thread for some reason. That mount looks very strong, I may try making one or finding someone to make some for me. Thanks guys |
07-07-2008, 07:50 AM | #7 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Here's what I did front and rear. Jay |
07-07-2008, 04:34 PM | #8 |
roktoy, where do your upper links mount to your axle? I see some sort of aluminum block up there now, did you do some sort of 3 link?
07-07-2008, 06:42 PM | #9 | |
Not the greatest pics to see but here are a couple..... Jay | |
07-09-2008, 09:07 AM | #10 |
Nice rig, should look sweet when its done. So I'm working on changing out all my rod ends to the revo ones and also going to install the revo driveshafts. Also looking to do the steering conversion. Just waiting for some parts. |
07-15-2008, 12:34 AM | #11 |
Ok well I got the steering switched to behind the axle. The front works very nicely, (I put on jeepernick's mounts). But the rear mount puts the servo in the way of the upper link. I dont really know what to do other than remake the mount. Any ideas? I'll post some pics tomorrow.
07-15-2008, 08:33 AM | #12 |
Ya lets see what the problem is because they worked great in my rig glad you like them |
07-15-2008, 10:04 AM | #13 |
Here at regular ride height its ok. But then with just a little articulation it hits the link. What do you think? Edit: Wow, sorry that first pic is so bad. |
07-15-2008, 10:06 AM | #14 |
slide the servo up from the bottom |
07-15-2008, 11:09 AM | #15 |
Hmm, ok I'll give that a try.
07-15-2008, 05:16 PM | #16 |
Well I tried switching it so that the servo is mounted under the plate but it still hits the link.
07-15-2008, 05:33 PM | #17 |
Can you bend the link? Jay |
07-15-2008, 06:46 PM | #18 |
as Roktoy suggested slightly bend the link, just enough so it will clear Or I would just install spacers on the upper links. but it could "jack" the link geomotry up... if there is any |
07-15-2008, 09:59 PM | #19 |
I installed some spacers between the servo and the mounting plate. That dropped the servo and it barely hits the link now. However the servo is really low now, almost in the way of things and it make take some hits on rocks. If I bent the link, wouldnt that also mess up the geometry?
07-16-2008, 08:33 AM | #20 |
im not sure how badly it would mess with your geometry if any... try it and you maybe able to just take out the spacers with the spacers in can you attach all your steering (horn links ect) and make it work? maybe I had my upper links mounted higher on my chassis, because mine worked sure you will figure it out, all part of the hobby |
