Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: just picked up a txt
Old 07-08-2008, 06:12 PM   #1
Default just picked up a txt
does anyone know where i can get new parts ,i want to rebuild the axles, any help would be appreciated
tat2INDY is offline   Reply With Quote
Old 07-08-2008, 06:19 PM   #2
TEAM MODERATOR
Reflection's Avatar
I don't have a TXT,but I seem to remember that some of the Clod junk will bolt up. I think the knuckles do and the CVD's might.
EDIT.....
Yep,guess the CVD's do....Thunder Tech Racing CVD Axles
Reflection is offline   Reply With Quote
Old 07-08-2008, 06:29 PM   #3
thanks for the info,
Old 07-08-2008, 07:14 PM   #4
What parts are you looking for? TXTs use the same inner axle shafts, outer axle shafts(stub shafts, although there are specific TXT stub shafts for TXT adapters and wheels), knuckles, and hexes as Clods. You can get new housings, input shafts, internal diff gears, and some other stuff from Tower:
http://www3.towerhobbies.com/cgi-bin...I=TAMC0280&P=X
The only problem are the upper gears which you can only get from from Tamiya. But they haven't had some of them for a long time and even list some as discontinued.
hawnmt is offline   Reply With Quote
Old 07-08-2008, 08:05 PM   #5
I recently did a rebuild and went through my txt. trying to find the 6x11x4mm bearings wasn't cheap or easy.
hairba11 is offline   Reply With Quote
Old 07-09-2008, 12:25 AM   #6
thanks for the replys ,these txt axles got a lot of history on them , so i want to stock up on parts just in case
Old 07-09-2008, 01:40 AM   #7
Well if you have the cash i would just upgrade the axle's that way your done for life. go to... hope it helps
http://rc4wdstore.com/advanced_searc...ds=txt&x=0&y=0
Bigsky is offline   Reply With Quote
