08-06-2008, 03:05 PM | #1 |
RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
| Locker for TXT
Options what you guys got? I know of the RC4WD ... are they good, do they hold up? I have smoked the stock R&P with JB Weld .... and even tried the gear placement trick... still keeps coming unlocked Thanks |
08-07-2008, 12:52 AM | #2 |
RCC Addict Join Date: Jan 2005 Location: Germany north
or http://www.rcalloys.com/pricelist/txtspool.html or 4:1 with hardened steel spool or if you like the stock 2:1 axle ratio remove the inner bevel gears drill out the lower gear and diff cup to 8mm glue the spool in with Loctite 648 |
08-07-2008, 08:40 AM | #3 |
I have the CVDs for it I would like more info on the 4:1 setup do you have a parts list? Thanks |
