08-25-2004, 08:15 AM | #21 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: TXT with LST tires on narrowed txt wheels Quote:
Jeep_boy02, I have my own web server so thats where I host my pics. I think Imageshack does go down from time to time. | |
08-25-2004, 09:20 AM | #22 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Jeep_boy I use sony image station. It's free and you can buy prints make changes it's pretty cool. Badger, I'll take some tonight. Though I'm not sure if they are gonna show up. |
08-25-2004, 10:19 AM | #23 |
If they don't show up with your camera, I can take some with mine if I see you this weekend at the comp. I think alot of guys could appreciate the bead locks you have especially if you have bolts in them now. |
09-12-2004, 08:37 PM | #24 |
Rock Crawler Join Date: Feb 2004 Location: The Gay NorthWest
will the lst's fit on narrowed txt wheels??? looks good badger |
09-12-2004, 10:40 PM | #25 |
Your joking right RSI? Read the Subject of this thread. |
09-13-2004, 07:41 PM | #26 |
well you had the beadlocks i was just wondering if they were needed ryan |
09-13-2004, 11:39 PM | #27 |
Yes you need some sort of bead locks or outer rings to hold the outer beads to the wheel because when you narrow the TXT wheels you cut each side of the rim off elimiating the outer rings that hold the tire bead on.
09-14-2004, 08:45 AM | #28 | |
Quarry Creeper Join Date: May 2004 Location: Neosho
09-14-2004, 09:13 AM | #29 |
Jeepboy, That method will not work for the LST's. The LST's inner diameter is larger then the txt tires, the LST's actually sit on top of the fins and require an outer bead that is larger in diameter. |
09-14-2004, 01:06 PM | #30 |
Badger you've got email @ badgerracing.com Oh and Jeep boy. the downside to cutting wheels like that is now there's a glued seem which is weaker(not that it's really an issue) but the main thing is I cut mine the other way and cut down the fins and I did NOT have glue my tires. They have never slipped not once. |
09-14-2004, 07:00 PM | #31 |
you cut yours the other way? - which is that? - cut inbetween the outer and inner bead on each side? - if so how much does that narrow it? enough I guess since your running them |
09-14-2004, 08:35 PM | #32 |
See I cut the portion of the wheel that holds the TXT tire. The bead surface then gets cut into the fins seen here. But this wheel was left alone to be used for a MAXX sized tire. My BFT's. The black rings are slightly larger in diameter to hold the large holed tires in place. Does that make sense? |
09-14-2004, 10:51 PM | #33 |
ya I get it now - thanks. are you selling those by the way? I got some jumbo swamp dawgs and cant decide whether to use X-75s or do like you have with the stockers.- whats your opinion? |
09-14-2004, 11:18 PM | #34 |
I bought some maxx adapters but didn't really want to lose any width. so I just figured I'd make the TXT wheels work. I don't like they X-75's they look stupid to me. So I figured I'd make my own option. I think they turn out sweet. So I made Badger a set.
09-15-2004, 07:44 AM | #35 |
I dont reallt like the X-75s either, but I am going to make a lock ring that covers them up a little - you still got them adapters? |
09-15-2004, 08:15 AM | #36 |
mine are like rckjeeps except i dont have the inner fins there is no fins at all on mine so i dont need bead lock then right? ryan |
09-15-2004, 09:23 AM | #37 |
I need them because it makes the wheel a larger diameter. See TXT tires have a 2.6" diameter and maxx sized tires have a 3.2 diameter (I believe). So I need the tire to rest upon those fins to make up the difference. Ryan are you using Clod wheels? if so, from what I've seen i don't think they work the same. |
09-16-2004, 07:53 AM | #38 |
no i am running txt wheels but i made up my own design for shopping them.... i went with bft's anyway from wut dirk told me he said they work very well with no modification, and even better with so i went with them... on the way now, andother tire that is a better then the lst is the jumbo swamp dawg narrowed 1-2 inches and siped the larger lugs in half but thats allot of mod so i just went wit bfts..... ryan |
09-16-2004, 09:16 AM | #39 |
Ya I'm really happy with the BFT's Icut the crap out of the tread too. I think the best mod has got to be the side lugs.
09-16-2004, 09:56 AM | #40 | |
