03-30-2005, 07:11 PM | #21 |
Rock Stacker Join Date: Mar 2005 Location: natick mass
what gearing do you recomend for a GD-600, on a mag mayhem? this is going in a e-maxx |
03-30-2005, 11:08 PM | #22 |
Pebble Pounder Join Date: Sep 2004 Location: Phoenix
one- the motor is in the back so i can run my battery up front but thanks for the tip. csr, thanks for that bit if info. guess I should have thought of that myself. lol |
03-30-2005, 11:10 PM | #23 |
hey csr, can you post a pic of your truck so i can check it out? or do you have it somewhere on this site?
03-31-2005, 03:00 AM | #24 |
Rock Stacker Join Date: Feb 2005 Location: portsmouth
make a saddle pack so you can mount the batteries on the front axle that will get some of your weight low and to the front and then you can turn your tranny and get that weight towards the front
03-31-2005, 06:18 AM | #25 | |
RCC Addict Join Date: Jun 2004 Location: SERCRC
There's some here... A few crawlin' pics and in the Southern Fun Run comp and get together threads. ;) | |
03-31-2005, 06:48 AM | #26 | |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
So now you see my point | |
03-31-2005, 10:12 AM | #27 | |
Rock Crawler Join Date: May 2004 Location: DFW, Texas
use a 18t pinion on the gd600.....that's the 2.5 reduction btw. This will give you about 177:1 Final gear ratio in 1st gear or 110:1 in 2nd gear. The Mag mayhem has more rpm's than a Lathe so you can get away with lower gearing. Works good. As fast as a slow walk with those size tires, but it has TONS of torque. Remember, you also have the option of locking the emaxx tranny in first OR second gear so you can try both to see which one you like better......or just use a servo/3ch radio to shift gears like me | |
03-31-2005, 12:44 PM | #28 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
I turned my gd600 down with my wifes metal nail file... worked pretty good.. makes one heck of a mess though... P.S. had to buy here a new file. |
03-31-2005, 01:15 PM | #29 |
Csr, I dont know why but my normal rotation motor is spinning everything backwards. I dont feel like replacing the motor so I just hooked it up the other way. Any sugestions?
03-31-2005, 01:39 PM | #30 |
| I'm not sure what you've got going on.... If the motor is wired correctly and the servo reversing switch is in the right position you should be going forward when you pull the trigger back. :neutral: |
04-01-2005, 09:20 AM | #31 |
Newbie Join Date: Jan 2005 Location: North Eh!
Looks sweet...I'll have to give this a try on one of my shafty's.
08-03-2005, 12:08 AM | #32 |
Rock Stacker Join Date: Apr 2005 Location: Rock Haven
Hi, i read about flipping the tranny. .... er...wat does it mean? which tranny? the centre gearbox? I'd like to install the gd600 too and run the batt in front. how do i go about doing this? sorry for asking newbie question. but my gd600 still on tthe way. so i got no real stuff to work my imagination. |
08-03-2005, 02:28 AM | #33 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
That will free up space in the front of the rig for your battery. | |
08-11-2005, 03:14 AM | #34 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
Ok, so another newbie has a question. Is it more worthwhile to get X-factor axles or the GD-600? I've decided a TXT is my next truck and I am trying to get ahead of the game if at all possible.
08-11-2005, 04:28 AM | #35 |
I would get both. Xfactor axles are wider and the gd600 will give you alot of power.
09-08-2005, 11:00 PM | #36 |
Hi all....hello again. Finally got my GD600 from Towers...after 45 days delivery...phew..... Tonight i'm goiing to start on my TXT crawler project....wish me luck ;) |
12-13-2005, 06:05 PM | #37 |
Newbie Join Date: Oct 2005 Location: New Hamburg
I was wondering... i have a stock txt-1 that im slowly trying to make into a crawler, i was wondering about the gd 600, i dont really like the idea of only using one motor so i was wondering if there is any way possible to fit it in with both motors? any info would be awesome. also i fried the stock speed controller and went to my lhs and they recomended i get a novak super duty i was wondering if this is any good or what would be a better choice ? thanks
12-13-2005, 06:38 PM | #38 | |
12-15-2005, 10:38 AM | #39 |
Im not to worried abot weight because im not very serious about rock crawling yet. Does anyone have info about the esc's from my last post thnx
12-15-2005, 01:14 PM | #40 |
"clock" (rotate) both gd600's... but be fare warned... you may break stuff with that much torque... i snapped stuff with 1 gd600 and a stock 540 can
