Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Which spring weight to use?
Old 01-24-2009, 09:02 PM   #1
Default Which spring weight to use?
Hi all, I've got a Jugg 2 and recently installed ESP's cantilever kit on it. The trouble is, I used 2.5lb T/E-Maxx shocks and it flops around like mad! Standing still the shocks are like 50% compressed.
What would be the ideal spring weight for general off road action with a bit of crawling thrown in? 6lb?
georeg123 is offline   Reply With Quote
Old 01-25-2009, 03:15 PM   #2
I am not sure on what spring to run. 6lbs seems like an ok start. Might need thicker shock oil or thinner shock oil too. Depending on how the spring makes the truck react.
You might want to try the shocks not on Cantilevers? That seems to be the hot ticket around here these days, no cants.
justadork is offline   Reply With Quote
