10-16-2005, 06:46 PM | #41 |
Rock Crawler Join Date: May 2005 Location: In front of my comp
Good job i cant wait till i get my TXT
10-17-2005, 10:49 AM | #42 |
RCC Addict Join Date: Apr 2004 Location: 5280
Where did you get your tape weights at? I would be interested in some for my TXT. Any more of you guys doing savage shocks and I will have to send the truck under the knife yet again. |
10-17-2005, 10:57 AM | #43 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
I tried to buy tape weights at at Discount tire but the wouldn't sell any to me. So I got them from Ebay.... http://cgi.ebay.com/ebaymotors/ws/eB...category=63699 Check this guys other auctions. |
10-17-2005, 02:50 PM | #44 |
Thanks for the heads up! I may try a couple of friends who work in the business first. If I can get the locally and you need some more let me know!
10-24-2005, 07:44 PM | #45 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
Tape weight are EASY to get! Just bring a 6 pack with ya!! |
11-14-2005, 08:05 AM | #46 |
Well, finally got the TXT out in a comp situation. The only other change I've made is that I am running it on 8 cells now. Even though the comp couldn't be completed due to issues with the local ranger, I am happy to say that all of my changes have been very worth while. The TXT totally conquered all areas I had problems with in the past, and now I am able to run pretty much even par with the Clods.
11-14-2005, 08:12 AM | #47 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I think jason and the rest of the Clodoradans called the ranger themselves, after they saw the TXTs playing before the comp got started. |
11-14-2005, 08:19 AM | #48 | |
11-14-2005, 08:26 AM | #49 |
So I think, since I only use the TXT for comps now since the TLTs are so much more portal, I am going to pull the lathe and put the stock motor back for wheel speed. That'll add just a bit more for comp worthiness.
11-14-2005, 10:11 AM | #50 |
I wanna be Dave Join Date: Jan 2004
I have to say....during the short amount of time I watched your TXT, it worked incredibly well. I'm scared.....a little.......
11-14-2005, 10:18 AM | #51 | |
11-15-2005, 10:52 PM | #52 |
| Better servo mount
Well, I love the giant scale servos and there is no way I am going back to the standard size, but this weekend while climbing the wall of death at our Flat Irons site, I found a weakness to them being so big. As the TXT violently tumbled down the wall it nailed the servo and bent the top of it back stressing the mounting tabs and breaking them. The servo itself worked just fine after the fall. And at only $40 they are tuff for the money. The cool thing is now I have a complete spare, I did take the servo apart and even though these are resin gears, they are HUGE , no way you're breaking these things! Plus if you do, a spare gear set is only $5. Anyway, So I got to thinking about how to prevent this type of breakage in the future and I decided that the top of the servo needed bracing or support in case of impact so that it wouldn't bend as it did breaking the plastic tabs. I used aluminum angle, threded rod and lock nuts to make a more secure mounting point distributing the pressure over the entire servo case. The black tube that you see is actually spare txt top links that I cut to length and drilled out so I could easily pass the 6/32 rod through. I simply painted it black. Anyway, the first picture shows the busted servo and the other two pics show the new mounting.. Last edited by cheapjeep2; 11-16-2005 at 07:59 AM. |
11-16-2005, 09:54 AM | #53 |
Looks like a much better mount. You gotta remember at the FlatIrons there is no such thing as an easy rollover! about how much rake do you have in your TXT Cheap? I have about 1" difference in front and rear ride heights, and it works out really well, along with the 40/60 links. |
11-16-2005, 09:56 AM | #54 | |
11-22-2005, 03:07 PM | #55 | |
Quarry Creeper Join Date: Sep 2005 Location: Minneapolis
11-27-2005, 03:47 PM | #56 |
| 8 cell battery position
I upgraded all rigs to 8 cells from 6, my TLTs I made custom hump packs that used the standard 6 cell stick pack configuratin, I then added two cells to the valley created by the other cells for a hump pack. I loved where my 6 cell stick packs were on the TXT but a hump pack would not work as the stick pack slides through the frame rails. I found 8 cell stick packs that are 3600 MAh. The 3600 cells plus the addtion of two more cells has gave it additional weight in the front. It climbed extremely well in the "almost" comp at Flat Irons. Anyway, I finally got around to taking pictures.
11-29-2005, 12:15 AM | #57 |
RCC Addict Join Date: Nov 2004 Location: Redding, CA
Why didnt you just mount it on the front links?
11-29-2005, 05:31 AM | #58 | |
11-29-2005, 06:15 AM | #59 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
Mike, it's called another"use common sense thing" besides with wheel weights, the chassis split, among other things, if he added the battery to the front and they change a course to nothing but dropoffs, he is screwed The truck looks awesome. very nice job.. :thumbsup: |
11-29-2005, 07:52 AM | #60 |
Thanks Twisted. Long before Dirk started his "viva la shafty" revival I decided that I wasn't going to give into the clods or give up on the TXT, just yet. And well I am very pleased with how it turned out. I even got kudo from Dirk himself, who'd have thought? I have been so pleased, I even sold a set of Clod axles I bought to build a clod! |
