02-08-2009, 07:19 PM | #1 |
Newbie Join Date: Jan 2009 Location: Watertown
| Need some help with ball links
I broke off one of the ball links that the lower right 4-link connects to on the front axle. What size are the stock TXT ball links? I just want to be sure before I buy replacements. Thanks
02-10-2009, 05:26 PM | #2 |
Newbie Join Date: Dec 2006 Location: Seiad Valley
Just get some Revo ball ends. They are alot better. The revo's will screw onto the stock links.
02-11-2009, 05:49 AM | #3 |
Rock Crawler Join Date: Sep 2008 Location: N.E. Mpls
Bring the rod in when you get new ones if hetting from lhs...The revo ends are better but require 8-32 threaded rod. I cant say if they will fit your rig tho...
02-11-2009, 06:09 PM | #4 |
Rock Crawler Join Date: Jul 2008 Location: E. City
The Revo ball ends are 1000x better than the stock ones. They will thread right onto the stock threaded link ends even though the Revo ends are a bit smaller, it just makes them fit tighter and will reduce the chance of it pulling off. You will get more travel with the Revo ends as well. They are stronger, more readily available and are well worth it. You could also get the Jato ball ends, those will actually extend your wheelbase as well, if you want to do that as well. You can add almost 2 inches to your rig just by using those. They are the same size just a tad bit longer.
02-12-2009, 08:00 PM | #5 |
Great! Thanks for the info.
