10-09-2005, 02:28 AM | #1 |
Newbie Join Date: Oct 2005 Location: CA
| Can this be done with stock links?
Is it possible to get a ~15" wheelbase using the stock txt links? Looking to to stretch my stock txt a bit. If so, any tips on how to do it? Thanks |
10-09-2005, 02:43 AM | #2 |
Quarry Creeper Join Date: Jun 2005 Location: DH
Switch the links around by putting the shorter link on the top and the longer link on the bottom and install the lower link above the axle instead on the bottom. And you'll get about 15.5 to 15.75 in wheelbase.
10-09-2005, 11:12 AM | #3 |
Usually, the flipping of the links top for bottom is accompanied with cutting the bottom of the chassis off, so whether the links are the correct length without a cut chassis, I'm not so sure. But doing the link swap, and cutting the chassis will get you a ~15.5 inch WB. Notice the holes in the upper links, they were the lowers before. And notice the location of the lower links inner mount hole? That was to get the caster correct at the axle. Doing this results in almost a 15.5 inch wheelbase. |
10-09-2005, 12:36 PM | #4 |
Rock Crawler Join Date: Aug 2005 Location: Asia
i thought caster wasnt an issue with crawlers in general ... is this needed for tranny types, specially the txt/jug?
10-09-2005, 12:54 PM | #5 |
Caster angle of the axle has a direct effect on the driveshaft's universal's angle. It's not real important, but to get a safe angle is important. Too much positive caster (kingpin leaning back) and you get bad universal angles. And there is an effect on steering, but when the truck is all twisted up on rocks, or on an incline, the angles are usually pretty far off from normal anyways.
10-09-2005, 03:07 PM | #6 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
I've got a 17" wheel base using 8 bottom stock txt links, nylon lock nuts and 26mm rod ends. See my thread aka chop, cut, rebuild...
10-09-2005, 07:47 PM | #7 |
thanks EeePee! usefull info to know.
10-09-2005, 08:12 PM | #8 |
Thanks for all the info. EeePee are these cross braces for the transmission? If they are do you have a pic on where they mount to the trans? Thanks |
10-09-2005, 10:01 PM | #9 |
They just sandwich the transmission. The only thing holding the trans are the two upper screws.
10-09-2005, 10:57 PM | #10 |
Thanks!! P.S. Nice camera you have!! I guess it's time to start cutting |
10-14-2005, 02:58 AM | #11 | |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
~Matt | |
10-14-2005, 07:31 AM | #12 | |
10-14-2005, 06:12 PM | #13 |
Rock Stacker Join Date: Mar 2005 Location: us
i just cut my chassis more and ended up with 17.5 i used short links up front top and bottom. long links in the rear on top and home made high clearance links on the bottom. its 60/40 or so. RZ
10-15-2005, 12:13 AM | #14 |
take that back with 6.8 ends it 18 inchs i need a limo body ill give it a try
10-24-2005, 08:03 PM | #15 |
Rock Stacker Join Date: Mar 2005 Location: natick mass
EeePee thanks for the pic i just did this to my brand new txt and it worked great, i totally forgot about needing longer driveshafts so i need to get thoes but other than that its a great mod
10-25-2005, 01:01 PM | #16 |
Rock Crawler Join Date: Aug 2004 Location: woods cross utah
no such thing as too long, ask any chic
11-04-2005, 04:29 PM | #17 | |
Newbie Join Date: Nov 2005 Location: Phoeix
Thanks Al | |
11-04-2005, 07:38 PM | #18 |
ya you do need longer driveshafts, long tmaxx 2.5 ones should work but imm using shortened revo shafts
11-04-2005, 08:23 PM | #19 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Yes, you will need longer driveshafts. I'd go with the Revos because they're light and bulletproof.
11-04-2005, 11:49 PM | #20 | |
Rock Crawler Join Date: Jan 2005 Location: Nanakuli
