09-06-2004, 09:07 PM | #1 |
Quarry Creeper Join Date: May 2004 Location: Hartford, Connecticut
| pic of my batt mount and rotated tranny
Hi guys! This is is for now, uploading to RCPics STINKS!!! I have about 10 more body off pics and about the same from crawling today, but I'll be here 'till next weeke uploading them! I'm going to the bar instead. http://www.rcpics.net/img/37784 |
09-06-2004, 09:13 PM | #2 |
Rock Crawler Join Date: Jul 2004 Location: Mt.View CA
| Re: pic of my batt mount and rotated tranny
you should have mounted your motor in the top of the gd 600
09-06-2004, 11:25 PM | #3 |
Bigred, any reason why????? Seems to work fine exactly where it is!!! The motor and reduction clear everything, and they are mounted down low. Mounting the motor in the opposite location would do nothing more than raise the location, and therefore, raise the CoG. Again, why should I mount it differently? Thanx!
09-06-2004, 11:45 PM | #4 |
Damn... I did the same thing on Saturday but not because I wanted too... had to do it to get a TXT/Jugg tranny to fit into a Rockraider chassis. It worked pretty good too. |
09-07-2004, 03:24 PM | #5 |
Toyo, it looks good! How much run time do you have into this setup? Do you still like it? I honestly think that rotating the tranny and going single motor/reduction unit is the single best mod that I have made to the truck. The stability is awesome!
09-08-2004, 02:34 AM | #6 |
Quarry Creeper Join Date: Jan 2004 Location: Austalia
fullmodtxt- use www.photobucket.com its alot better..free and you can use the [img] tags to put the pics directly on the site..[/img] |
09-08-2004, 04:37 PM | #7 |
Driveshaft angles okay?
09-08-2004, 11:03 PM | #8 |
Pebble Pounder Join Date: Aug 2004 Location: Moab
Hey Toyofast, every time I see pics of your rig I think to myself..'that rig would look great if he'd just put some big tires on her' anyhoo, I like your set up, got me thinkin... |
09-08-2004, 11:11 PM | #9 | |
| Re: pic of my batt mount and rotated tranny Quote:
Well... for me, they worked for that one day. I wasn't happy with it but it worked. The rear angle was fine, the front had some issues and I wound up screwing up my front driveshaf a bit....it was worth it for a day of crawling. | |
09-08-2004, 11:14 PM | #10 | |||
Not sure yet.... Quote:
