10-28-2005, 08:16 AM | #1 |
Newbie Join Date: Mar 2004
| my txt
after a long wait i finally got it!now i need help i ndoin this ,coz its my first time to run electrics..he sent it to me with the esc wires cut and idk to which wire ill solder them.and i also wanna know where do i mount the batts?this txt is kinda customized..im probably the 3rd owner. so if u know this truck pls help .. if u noticed on the 1st pic one wire is connected to both motors..and 4th pic is how the esc was sent to me.. |
10-28-2005, 10:58 AM | #2 |
- First thing i would do is ditch both the motors and pick up a lathe motor if you can. if not take one the motors off. - For the battery and where to mount them, most people mount them on the top links you dont want to mount them to chassis. here a write up that one the members did while back that should help you with the wire problem. http://www.rccrawler.com/evx.htm Just wondering who did you buy it from ? |
10-28-2005, 06:29 PM | #3 |
I wanted to try out the two motor set up (thinking of the Aussies), and wired them in series, and used 9 tooth pinions. With a 6 cell 3300 battery pack it does okay really. When floored it's exactly a medium paced walking speed. It has enough power to do 90% of what it needs to, in a wheel grabbing bind both motors will stall out, and maybe under really extreme situations. But you shouldn't be in a wheel bind anyways, and the extreme situations are driver error. Motor braking is way awesome, like for downhills. Lathe motors with 9 tooths would be way slow, too slow. Wheel speed is good to have when needed. Maybe different pinions on Lathes, I could try that, eventually. I remember that truck, only because of the use of the cut metal U shape, and black plastic piece on the side. He slid the 6 cell stick battery through the frame, and used the black thing to hold it in place. I know nothing about the EVX ESC. |
11-03-2005, 11:01 PM | #4 |
ok eepee u r right that is where he mounts the batt..anyway i got everything set up but i encountered another problem..its the rear wheel steering...when i turn it u hear a clicking cound like the teeth of servos grinding..but if i take out the horn everything is good on the servo..do u have any mounting suggestions on this kind of set up? thanks [img=http://img38.imageshack.us/img38/3743/dsc017842dl.th.jpg] [img=http://img38.imageshack.us/img38/4900/dsc017855ta.th.jpg] |
11-04-2005, 10:06 AM | #5 |
ok i got it working .i changed the servo ..the servo was bad..anyway i tried it and i liked the suspension travel and only thing that maybe it needs is different tires and wheels the one i have now are too big..
11-04-2005, 01:50 PM | #6 | |
