11-09-2005, 06:44 PM | #21 | |
Rock Crawler Join Date: Jul 2004 Location: Mt.View CA
any way your truck still looks great. | |
11-10-2005, 02:47 PM | #22 |
RCC Addict Join Date: Jun 2004 Location: SERCRC
| Here are body off shots as requested. Like I said, I'm not happy with it so it'll be changing soon. ;) |
11-10-2005, 04:06 PM | #23 |
| I can't believe the GD 600 is clocked, and the motor is STILL that high up there! How about turn the tranny on it's side. The good side, that'll lay it flat. |
11-10-2005, 04:08 PM | #24 |
RCC Addict Join Date: Nov 2004 Location: Redding, CA
You might try to lower it about an inch. Then use some high clearance lowers with a carrier bearing drive shafts? And it looks like you could lower the tranny about an inch, just how it is. Or lay it on its side like Eeepee said. |
11-10-2005, 04:12 PM | #25 |
Or upside down, like TXTFun (I think).
11-10-2005, 04:19 PM | #26 |
Maybe some wideners and smaller diamiter tires?
11-10-2005, 04:54 PM | #27 |
| The TXT is getting totally rebuilt from the ground up. I got 'er stripped down, nothing left but a pair of axles. I doubt I use the stock tranny. Gears, maybe, but not the case. I'd like to try a AE or Losi tranny. EDIT: Just won a AE T3 Stealth transmission off Epay. ;) The Stealth is fairly durable. I only stripped one gear in all my years of racing Associated trucks and buggies with low turn modifieds. Not sure if I can fit the GD600 on it...... if not a planetary gear reduction will work. I'll post up more pictures when I decide which direction I'm going with the truck. The shafty with 'stick' clearance idea didn't work out. :-( Last edited by CSR; 11-10-2005 at 07:44 PM. |
