Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Tranny & Chassis cutting with more PICS UPDATED (9.28.04
Old 09-29-2004, 05:50 PM   #41
Default Re: Tranny & Chassis cutting with more PICS UPDATED (9.2
yup I moved it up about 1/2 an inch. it's the only way to get that inch of clearence. So you move it up 1/2" then cut off 1/2" inch. You cut off the lower gearcase bolt too. See the first pic.
rckjeep is offline   Reply With Quote
Old 09-29-2004, 11:19 PM   #42
TRD
BADGER
COULD YOU SHOW SOME PICS OF YOUR LINKS ?? RCKJEEP MOUNTED HIS LINKS IN HIS CHASSIS BRACE HOLES . WHAT IS THE DIFFERENCE ?? I LIKE HOW YOU MOUNTED YOUR BATTERY. WHAT IS BETTER . ARE YOUR LINKS STOCK? THANKS TRD :?
TRD is offline   Reply With Quote
Old 09-30-2004, 12:08 AM   #43
Diggin' the new SCX10 II!
badger's Avatar
Originally Posted by TRD
BADGER
I don't think the search button has killed anybody yet, but it still does not get used.
Goto my gallery and you will see my pics of all my modifications. Click on the picture 2 times (once on the thumbnail, and the once more on the picture to get a HUGE detailed pic).
http://rc.badgerracing.com/modules.p...php&page=1
No my links are not stock.
Big difference in mounting of mine and rckjeeps, my links are mounted to the same mounting point on the chassis. This supposedly help eliminate the TXT body roll from side to side.
I too like my battery mount, it was simple and did not cost anything.
You asked what is better? Of coarse mine is better!
badger is offline   Reply With Quote
Old 09-30-2004, 09:19 AM   #44
AFJ
So it begins I took my dremel with cut-off wheel and hacked first chassis plate, i have left about 1-2 mm of space from place i planned to cut so if i made error nothing bad happens. And about cutting the tranny did you cut only the mounting tabs or the screw mount on the bottom also? Ive thought to make like ive seen here, to make a skid with a slot that the bolt will go into, therefore mounting the tranny's lower end
AFJ is offline   Reply With Quote
Old 09-30-2004, 09:25 AM   #45
the pics tell all.
Old 09-30-2004, 02:33 PM   #46
Ok I just drove my truck in a spot that I went before the mods and what difference. I could climb stuff I never had a chance before. WOW! It's really amazing. Can't wait till I have some decent servos on again. The Futaba S3003 is struggling.
Old 09-30-2004, 06:35 PM   #47
TRD
thanks badger i went through all of you post and did not see what i was looking for . but thanks again
TRD
Old 10-01-2004, 09:59 AM   #48
badger's Avatar
TRD
What are you looking for that you could not find on this site?
I am still looking for my hot girl avatar... she dissapeared... I think the prudes got to her.
Old 10-01-2004, 06:24 PM   #49
TRD
PICS OF YOUR TRUCK !
Old 10-16-2004, 07:39 AM   #50
like the skid
spicollie is offline   Reply With Quote
