05-20-2009, 07:22 PM | #1 |
Rock Stacker Join Date: May 2009 Location: lake elsinore
| MY TXT with some CHASSIS MODS
not all finished yet but here is the chassis so far. tell me wat yea think or any suggestions |
05-20-2009, 11:45 PM | #2 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
Lookin good. Next move, get rid of those bumpers... and make new servo mounts. There is a thread somewhere that someone designed a mount, and has all the measurements on... If you cant find it, PM me with your email, and i will send it to you( i saved it to my pc)
05-21-2009, 12:06 AM | #3 |
thanks man. yea thats what i was planning on doin. gotta see if my dads got some aluminum that i can use or gotta get some. not sure wat transmission i should use. i have the txt 1 transmission and i have an emax transmission laying around. wat one do you think?
05-21-2009, 12:13 AM | #4 |
Do some reading in the txt section. An Emaxx trans is a pretty common swap... But, I still run the original (txt) trans in my rig. Im running stock txt trans, GD600, integy 45t, full size losi claws, on 3s lipo. Even with the emaxx trans, you might need a higher turn motor, more volts, or a gear reduction. Are those the tires you plan on running? |
05-21-2009, 09:10 AM | #5 |
oh ok cool. no i plan on getting some bleadlock wheels and tires. hey wat hex do i need to get to put 40 series tires on my truck.
05-21-2009, 01:06 PM | #6 |
Depends... some are 14, 17... You might even see 23mm... not sure, When you look for wheels, you will haveto buy adapters for them. Are you going to rin the 12mm brass hexes then adapters?... Or you could look on tcs crawlers, for their adapters. |
05-21-2009, 07:09 PM | #7 |
you need to be a member for 30 days... and have 30 tech related posts. Or buy a star for $20, and have access to classifieds, Giveaways, and support the site.
06-21-2009, 12:03 AM | #8 |
Quarry Creeper Join Date: May 2009 Location: lake elsinore
06-28-2009, 09:50 AM | #9 | ||
RCC Addict Join Date: Apr 2004 Location: 5280
I am still running the stock trans with the lower mounting ears cut off. I have been using them for 5 years now and they take a good beating, but with a 10T puller on 3S lipo I have been eating up gears so I am going R2HD for the next version of my truck. Quote:
You don't always need the GD600 with a TXT trans, if just depends on the motor. I ran a GD with a Mag Mayhem motor and the OG Crawlmaster, but since going 10T Puller I haven't needed it. Pulled out the GD and run the puller straight into the trans. With that motor on a 3S you have plenty of low end and control down low and lots of top end too! | ||
06-28-2009, 02:58 PM | #10 |
sell it to get some more stuff for your ax10 so you can compete with me! |
08-19-2009, 12:42 PM | #11 |
That is a nice looking txt, any further progress on it.
