10-01-2004, 07:09 PM | #1 |
Quarry Creeper Join Date: Aug 2004 Location: Guntersville
| 1/4 SCALE SERVO MOUNTS.LET'S SEE'EM
I'd like to find a diffent way to mount my 1/4 scale servo on my txt.
10-06-2004, 09:36 PM | #2 |
| Re: 1/4 SCALE SERVO MOUNTS.LET'S SEE'EM ANYONE |
10-07-2004, 02:51 PM | #3 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
i have to wait 2 more weeks until i get my servos... both are Hitec, one is a HS-805BB 1/4 scale and one is a HS706MG. im curious how they are going to work but acording to my measurments they should fit. My mounts are made from a piece of 90 degree bent aluminum from Home Depot in the screw isle, it was like 5 bucks then i simply mounted it to the top of the axle(after it was cut out to fit around the axle housing and cut to lenth) and then used the stock arms for the 1/4 scale from the F-tree on txt to mount it. right now it houses 2 hs605bb.... didnt work like i wanted...... sooooo im going bigger...1/4 scale!!!! i'll have pics tomarrow so you can see what i am doing.
10-08-2004, 08:17 AM | #4 |
Here are some pics of my home made home depot brackets, you can either look at the pics individually or just click next or previous in the photo album to veiw them all. http://pg.photos.yahoo.com/ph/mmalms...pg&.src=ph http://pg.photos.yahoo.com/ph/mmalms...pg&.src=ph http://pg.photos.yahoo.com/ph/mmalms...pg&.src=ph http://pg.photos.yahoo.com/ph/mmalms...pg&.src=ph http://pg.photos.yahoo.com/ph/mmalms...pg&.src=ph i hope that this helps |
10-12-2004, 09:31 PM | #5 |
Rock Stacker Join Date: Jun 2004
vary nice work . when you cycle the suspension do you have any clearance problums ??
10-14-2004, 07:48 AM | #6 |
Nope, it sticks out far enough that it just clears the frame... course, i just ordered the suplies from www.mcmasters.com to make custom links ... well... longer links and i am going to extend the factory drive shaft.. I will probubly post those pics when im done.... should be interesting.
