02-04-2010, 10:01 PM | #1 |
Pebble Pounder Join Date: Aug 2008 Location: marlborough, ct
| upgrade jugg1
when i dig up old threads for the knowledge its all dead end links, and no more photos. just received a jugg1 today and both diffs and trans are blown. It took all i had to buy this (not knowing of condition) So I know i need new axle cases and top gears for jugg2 or txt. Can somebody sent me a list of exact parts needed. That would be awesome. Also whats the most economical approach to trans. I want sturdy which is why i bought this. (not knowing its a jugg1) also any pics with setups on jugg chassis. Thanks in advance -ben
02-05-2010, 06:00 AM | #2 |
Newbie Join Date: Aug 2008 Location: Tilburg (the Netherlands)
02-05-2010, 08:18 AM | #3 |
Rock Crawler Join Date: Jul 2004 Location: Salt Lake
Hey, this is kinda off topic, but I notice you're in CT. You should hop over to NERCC.net. It's the club for the northeast. Good Luck with the Juggy! |
02-05-2010, 10:24 AM | #4 |
so what i came up with was getting all txt stuff from tamiya. Except the bevel gears on top. which are discontinued. Anybody know where to get them without getting the 75$ bag from tamiya. need #9805814 mr17 and mr18. Any aftermarket gear option?
02-05-2010, 10:31 AM | #5 |
RCC Addict Join Date: Jan 2007 Location: caldwell,idaho
i just ordered the txt1 tranny gears for $8 bucks i am hoping they are the same as the jugg 1.
02-05-2010, 12:52 PM | #6 |
If you need TXT trans gears I accidentaly bought a set from tower PM me if your in need of those
02-05-2010, 05:35 PM | #7 |
i installed the gears into the jugg1 and they fit ,parts from the txt1 are the same for the tranny.
02-05-2010, 08:59 PM | #8 |
well i found out the trans noise was just a couple shot aluminum pinion gears with a really loose mesh, and an extra long screw hitting armature in motor. also the tranny gears look new. says 1999 on them. still trying to find a way out of buying 75$ die cast bag. need the beveled gears on the top loader part of the axle.
02-06-2010, 03:09 AM | #9 |
Newbie Join Date: Dec 2009 Location: Netherlands
Hi aircooled, I buy a lot of new juggernaut / TXT items in this store. http://www.modellbauseidel.de/index....T-1-je-2-Stück- This store has everything of it. It's in germany, but as far as i know they ship worldwide. Paypal payment is also available. hope it helps ya! with regards, Endy |
02-06-2010, 10:44 AM | #10 |
they have it, but won't ship to usa. :-(
02-07-2010, 11:51 AM | #11 |
I think this one should do the trick http://thescalerstore.altervista.org...roducts_id=209 With regards, Endy |
02-07-2010, 02:29 PM | #12 |
thanks it said they have one in stock. i ordered it. hopefully it will work out. here's a pic of the juggs current condition |
02-08-2010, 06:46 AM | #13 |
just got a refund. the scaler store didn't have it.:-(
02-08-2010, 10:31 AM | #14 |
| hi aircooled67, That's a very nice juggernaut you have there Too bad the shop couldn't help you any further. you can give this one a try: http://www.airlandhobbies.com/p-2381...280-short.aspx Then i m fresh out of ideas, in the usa i don't know anything else With regards, Endy |
02-15-2010, 06:23 PM | #15 |
Newbie Join Date: Feb 2010 Location: New York
Ben, what parts do you need exactly? I have the original set of Jugg 1 gears that were never used, but I would not recommend building it up as a Jugg 1. Tower Hobbies currently sells the axle and trasmission cases. When Tamiya upgraded my Jugg 1 to the Jugg 2 they sent me a gear bag with new transmission gears, shafts that have half moons to keep from rotating in the case and heat sinks to attach to these shafts. The axles got new bevel gears and metal bushings if I recall (may have been ball bearings?). The problem with the Jugg 1 was that the bevel gears meshed, but were not fully supported. The Jugg 2 has longer shafts that are supported by bearings on each side. So the entire axle and tranny case was stamped with a 2000 date code. The differential unit that was used on my Jugg 1 is that same as in the Jugg 2, except that they replaced the 3 small screws that hold it together with longer ones. They had sent me an instruction sheet and new screws to use. |
