08-27-2004, 10:48 AM | #1 |
Pebble Pounder Join Date: Jun 2004 Location: Oklahoma
| Reverse Wiring On TXT-1
I have read that some of you are reversing the wiring to the motors, so that you can run the battery pack up front. That would cause the motors to reverse it's rotation. I have just seen these motors and was wondering if this would do the same thing without altering the wiring? Also would you want to buy these motors over their counterparts? http://www2.towerhobbies.com/cgi-bin...XW929&P=ML |
08-27-2004, 11:11 AM | #2 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: Reverse Wiring On TXT-1
You are correct. That would be a good buy since you would not have to wire the stock can motors in reverse. I have wired my stock txt can motors in reverse and they run HOT. So does my ESC without a fan. So if you buy a reverse motor then your elctronics should last longer since they should run cooler. I am getting a mammoth gear reduction next week, does anyone know if I need a normal rotation or a reverse rotation motor for that? I don't know if the gear reduction reverses things with the gears. |
08-27-2004, 11:20 AM | #3 |
Hey thanks Badger
08-27-2004, 12:49 PM | #4 | |
Quarry Creeper Join Date: Jan 2004 Location: Bend, OR
| Re: Reverse Wiring On TXT-1 Quote:
08-28-2004, 03:07 AM | #5 |
Pebble Pounder Join Date: Apr 2004 Location: Wollongong - Australia
If you run your motors in reverse you will have heaps less power and much shorter runtimes as well. I did it for a while and dont reccomend it. Oh yeah and Badger, that new avatar of yours is, in one word, excelent. |
08-28-2004, 12:24 PM | #6 |
Do you think that those new mayhem motors that are reverse rotation will be less power than the normal mayhems?
08-28-2004, 08:46 PM | #7 |
Nah they are exactly the same, they just turn the other way. You have to use 1 normal and 1 reversed in a clod so they have to be fairly well even.
08-28-2004, 09:34 PM | #8 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
After all, there's not a reverse-rotation Johnson for the clods. | |
04-18-2010, 01:36 PM | #9 |
Newbie Join Date: Apr 2010 Location: Boston
Really?? i was running my txt backwards to have the weight of the battery in the front...and i did not notice anything bad...at first i had the stock motors...then i wired in two trinty speed gems 17 turn doubles with zero degree timing
04-23-2010, 04:45 PM | #10 |
Rock Crawler Join Date: Aug 2007 Location: Dela-where?
whoah! six years... is this a record?!? |
06-04-2010, 02:53 AM | #11 |
Pebble Pounder Join Date: Mar 2007 Location: cleveland
LMAO!!! I think this is the record |
