Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Another suspension find
Old 10-22-2004, 03:13 PM   #1
MODERATOR™
EeePee's Avatar
Default Another suspension find
Tinkering, it's what it's all about.
Found this one. The linkage is fixed, so it's acting as a mounting point for the shock.
It so happens, that you can find 4 different mounting angles by moving the link around.
Accomplished without modding anything.
A quick review; limited articulation, and stiffer than stock, with very little twist.
EeePee is offline   Reply With Quote
Old 10-22-2004, 03:37 PM   #2
MODERATOR™
EeePee's Avatar
Default Re: Another suspension find
Here's where I ended up. Full circle practically. Outboard cantis.
Started inboard w/80wt oil. Ditched the cantis for a no travel/articulation set-up.
Went springless for a few hours.
Then the like the post above with 3 different shock angles.
Now here. Which is the best so far.
