10-22-2004, 03:13 PM | #1 |
| Another suspension find
Tinkering, it's what it's all about. Found this one. The linkage is fixed, so it's acting as a mounting point for the shock. It so happens, that you can find 4 different mounting angles by moving the link around. Accomplished without modding anything. A quick review; limited articulation, and stiffer than stock, with very little twist. |
10-22-2004, 03:37 PM | #2 |
| Re: Another suspension find
Here's where I ended up. Full circle practically. Outboard cantis. Started inboard w/80wt oil. Ditched the cantis for a no travel/articulation set-up. Went springless for a few hours. Then the like the post above with 3 different shock angles. Now here. Which is the best so far. |
