11-24-2004, 11:35 AM | #1 |
Newbie Join Date: Nov 2004 Location: San Jose, CA
| TXT-1 Wheel Base Extension
Hey just had a question. Im going to extend my wheel base, just wanted to know how much should extend it by? I have all the parts to make the extended links and driveshafts.
11-24-2004, 11:40 AM | #2 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: TXT-1 Wheel Base Extension
Between 15" and 16" seems to be the popular WB for a TXT. I run mine at 15.5" and it works very well. |
11-24-2004, 12:19 PM | #3 |
Rock Crawler Join Date: Jan 2004 Location: Santa Cruz, CA
I run mine at 16.75"
11-24-2004, 03:56 PM | #4 |
I'm only at 15 inches, and I've never tried longer. But it's oh so good. |
11-24-2004, 04:25 PM | #5 |
RCC Addict Join Date: Jun 2004 Location: SERCRC
| Re: TXT-1 Wheel Base Extension I'm currently at 15.25". I'm gonna be making some changes to the suspension soon and will probably stretch it out at least another 1/2". I had it at 15.25" because I had only front wheel steering for a while, got 4WS now so I can go longer and still have a good turning radius. |
12-01-2004, 03:03 PM | #6 |
great thanks for the ideas i think ill run mine @ 15.5 to 16 thanks |
12-01-2004, 03:51 PM | #7 | |
| Re: TXT-1 Wheel Base Extension Quote:
When will your truck be ready to crawl? I think the nor-cal guys are going to get together next weekend 11/12. Keep an eye on the get-together forum to get updates. | |
12-01-2004, 04:44 PM | #8 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Badger don't you mean dec. 12th or did you mean sat. the 11th & sun the 12th. either way its crawl time |
12-01-2004, 04:47 PM | #9 | |
12-15-2004, 07:40 PM | #10 |
Newbie Join Date: Feb 2004 Location: chicago
So if i was to extend my wb to 15.50-16.00. How long should i make the links?
12-15-2004, 08:12 PM | #11 |
Here's an easy to find out your links measurements. First figure out where you are going to mount your links on the frame. For example I mount my uppers in the hole that the crossmember was mounted. Have the frame supported and your desired skid clearence hieght. Then you mock up your axles(with tires mounted) to the desired wheel base length. Make sure the frame is centered between the axles. Unless you want to run the rear longer than the front. But we'll get into that later. With the frame supported and the axles sitting on the ground and chaulked to stop them from rolling. Then measure from the axle link mount to the hole in the frame you wish to use. Try to measure from the center to center of the holes. Then subtract the the length of the rod end(going from the center of the hole to the end of the plastic) X 2 and that will give you your link length. Get it? Maybe I can do an article for the board with pics.
12-15-2004, 08:14 PM | #12 | |
12-16-2004, 02:50 AM | #13 |
Pebble Pounder Join Date: Apr 2004
actually ive found that with stock links and cut frame i got about 4,5" clearance under tranny and 16+ wheelbase, everything is stock. But now ive found very big issue, i dont know how to make skid properly so it will fit, i want to do similar to what RCKJeep did (he inspier me )
12-16-2004, 08:14 AM | #14 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
I had mine all te way out to 17.5 inches and when crawling it was.. ok, it didnt suck but when i lenthened the links i also lenghtened the canti rods to gie like 1/2 inch more clearance. like i said it was ok... now im in the middle of choppin my frame,im shortening my wb to 15.5 and i raised the tranny, relocated the cells to the rear axle, added revo shafties and cut the tires and glued on lugs..... my babies n pieces right now... litterally.
