Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Rig stats- Compare your Crawler
Old 09-23-2004, 05:08 PM   #1
Default Rig stats- Compare your Crawler
We are doing this on my 1:1 4x4 clubs site and I thought it would be fun here too.
Here's mine, newly configured.
WB 15 1/4"
TIRE SIZE 6 3/4"
TRACK WIDTH 14 5/8"
DIFF CLEARENCE 2 1/8"
TRANNY SKID 4 1/4"
WEIGHT 9.75 LBS.
TFG 7 1/2"
(Top of frame to ground)
whats the stock TXT tranny measurement? trying to compare and I forgot to measure before hand.
rckjeep is offline   Reply With Quote
Old 09-23-2004, 07:03 PM   #2
CSR
Default Re: Rig stats
WB 15 1/4"
TIRE SIZE 6 7/8" (LST's on narrowed wheels, no foams. 6.5" with the weight of the truck on them)
TRACK WIDTH 15"
DIFF CLEARANCE 2 3/16"
TRANNY SKID 4 1/4"
TOP OF FRAME TO GROUND 8 1/8"
WEIGHT 10 LBS 13 OZ
CSR is offline   Reply With Quote
Old 09-23-2004, 10:29 PM   #3
RSI
wheelbase 17 3/4
track 15
diff clearence 2 1/2
skid plate clearence 4 3/4
weight not sure yet
RSI is offline   Reply With Quote
Old 09-23-2004, 11:00 PM   #4
DUDE's Avatar
TLT TJ-10
really cool
good driver.
12.375 wb
6lbs.
5"+ tire.
3.5"+ belly claence
needs a cog overhaul.
Oh ya and it wheels and crawls.
Hay at least it is a txt jr.
DUDE is offline   Reply With Quote
Old 09-24-2004, 12:09 AM   #5
Diggin' the new SCX10 II!
badger's Avatar
Here's my TXT measurements.
WB - 15 1/4"
TIRE SIZE - 6 3/4"
TRACK WIDTH - 14 7/8"
DIFF CLEARENCE - 2 1/8"
TRANNY SKID - 5"
WEIGHT heavy (not sure)
badger is offline   Reply With Quote
Old 09-24-2004, 09:48 AM   #6
Default Re: Rig stats- Compare your Crawler
Wheelbase - 16"
Tire Size - 6"
Overall Width - 13½"
Diff Clearance - 2"
Tranny Skid - 4¼"
Weight - 8lbs
Top of Frame to Ground - 6½"
Overall Height 10” (72 Chevy Pickup)
Joe
kona_joe is offline   Reply With Quote
Old 09-25-2004, 11:46 AM   #7
16 inch wheelbase
6.75 inch TC tires
14.25 inches overall width
7.5 inches top of the frame to ground
9 inches to the top of the cantis
2.25 diff clearance
4.375 center clearance
I don't know what it wieghs, but it is heavy! All of the wieght is in the tires though. I've reduced as much wieght as I could in the chassis, and added 1.5 lbs of bbs in each front tire. The TerraCrusher tires are probably the heaviest around to begin with, except for maybe Kongs!
fullmodtxt is offline   Reply With Quote
Old 09-25-2004, 12:19 PM   #8
XTM X-Factor Axles
Traxxas E-Maxx Transmission
Tamiya TXT-1 Lightweight Frame
Losi LST’s on stock wheels
Wheelbase: 15.75”
Overall Length: 23”
Overall Width: 17”
Differentials Ground Clearance: 2.25”
Transmission Ground Clearance: 4.375”
Tire Diameter: 6.875
Hey, it’s part TXT-1
NeoSlayer888 is offline   Reply With Quote
Old 09-25-2004, 12:38 PM   #9
WB 15 3/4"
TIRE SIZE 6 1/4"
TRACK WIDTH 14 1/2"
TRANNY SKID 4 1/2"
WEIGHT 6 LBS
TFG 7 1/2
jordanator62 is offline   Reply With Quote
Old 09-26-2004, 01:21 AM   #10
Alright Jordanator how'd you make a 6 lb. rig? Mine's just under 10 loaded, one motor, 6 cell pack, rx pack, and electronics.
Old 09-26-2004, 01:32 AM   #11
WB: 15 1/4
legnth 22
track: 14 1/2
tire 6 1/2
maxx travel 9
toftg 7
skid clearence 4 1/2
diff high 2 1/4 low 1 3/4
weight ???? heavyish? :?
trube frame
indepent 4ws
cut jugg tires
extreme is offline   Reply With Quote
Old 09-26-2004, 09:00 AM   #12
Wheelbase - 16"
Tire Size - BFT's so about 6 3/4"
Overall Width - 16"
Diff Clearance - 2 " using skid plate
Tranny Skid - v shaped low point 4 7/8"
Weight - heavy
Top of Frame to Ground - 9"
simtechray is offline   Reply With Quote
Old 09-26-2004, 11:10 AM   #13
Location: orange county n.y. , building the hydro crawler
wb 16.5"
diff clearance 4" hybrid maxx axles
width 16.75"
center clearance 6"
tfg 8.75"
weight ? not bad
tire size 5.65"
sambmx is offline   Reply With Quote
Old 09-26-2004, 12:27 PM   #14
rkjeep,
i dont f'ing know!!! it was like magic. im not sure it is all that accurate though cause i weighed it on a bathroom scale..lol. but there isnt much chassis left, my tires are 2 1/2 inches wide, with 4 oz of bb's in each front tire, no elecronics or battery tray, so there isnt much in it...
i need to get a fish scale.....
jorDANK
Old 09-26-2004, 01:26 PM   #15
that can't be accurate. You've got 1/2 lb. in the front tires alone. In just BB's I used a hanging scale at work. same as a scale at the grocery store.
Old 09-26-2004, 03:55 PM   #16
hmm i should just walk into the vegtable section of the grocery store with my truck, and throw it on a scale before anyone can say anything...lol
Old 09-26-2004, 04:41 PM   #17
thats what id do if there was one closer than 10 miles from here. whats the worst the can do,... errr humm sir that scales for produce only .
Old 09-26-2004, 06:10 PM   #18
haha, i think i might go stop by the local grocery tonight...lol, this will be funny...
Old 10-01-2004, 08:00 PM   #19
SO Jordan what did the grocery store guy say? I've been dyeing to hear the story. and what's the new weight?
Old 10-02-2004, 02:43 AM   #20
17" wb
6" clearance under tranny
6 3/4" bfg tires
2 3/16" axle clearance under pumpkin
13 3/4" wide
9 7/8" to top of frame
TwistedKreations is offline   Reply With Quote
