Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: txt axle questions
Old 12-18-2010, 04:42 PM   #1
Default txt axle questions
has anybody narrowed a txt axle and can you narrow a txt axle
slashkiller is offline   Reply With Quote
Old 12-18-2010, 05:18 PM   #2
TEAM MODERATOR
Reflection's Avatar
Not sure what the stock width is, anything is possible with the right tools and a bit of custom work. This guy got his down to 9 1/4" hex to hex.
Parker's 2.2 Tuber
Parker's 2.2 Tuber
Honestly, you might be better off just going with Axial axles. If you want more beef than that, another axle that's easy to narrow is the Twin/Mad Force axles.
Reflection is offline   Reply With Quote
Old 12-18-2010, 05:24 PM   #3
i was try to make them fit under a jeep jk body and scx10 frame and trans
Old 12-18-2010, 06:34 PM   #4
I did this set up but the problem was the top of the axles where hitting the scx-10 chassis. These axles where narrow alsoi had narrow under 10 outside tire to outside tires.I was also running cvds in front.
1beatjeep is offline   Reply With Quote
Old 12-18-2010, 06:54 PM   #5
how did you narrow them
Old 12-18-2010, 07:39 PM   #6
yes tell us more
muddawg is offline   Reply With Quote
Old 12-18-2010, 08:36 PM   #7
Cut the axle housing glue made some alumm. brackets and used the holes in cases.here is some pic
Old 12-18-2010, 08:58 PM   #8
how did you narrow your axles
Old 12-19-2010, 07:40 AM   #9
Cut the cases made little brackets to hold cases together.On the axle shaftes had a buddy weld them up.
Old 12-19-2010, 07:27 PM   #10
thanks man might have to try it
Old 01-05-2011, 10:06 AM   #11
Which Steering Knuckles are those?
CraZySteve is offline   Reply With Quote
Old 01-05-2011, 11:37 AM   #12
If you go under ebay look up TXT-1 there on the bottom for like 20.00 shipped
