![]() | #1 |
Pebble Pounder Join Date: Jun 2009 Location: Hudson, NH
Hi All, Newbie to the site ![]() ![]() I do have 2 brand new Kyosho Mag Mayhem 22t motors and some 10t and 13t pinions as well. I would like to use these with a gear redux unit From what I have been reading... It looks like a gear reduction unit along with a single motor will fit the bill as a good starting point (along with removing some excess weight. ) I am looking at the following 3 units
Help a Newbie out! - Wanting to hear some thoughts! Thanks in advance! - C ![]() |
![]() | #2 | |
| ![]() Quote:
I took the gamble - I wound up buying the HPI Wheel King Gear box - for starters I am going to use the stock 540 can wired backwards. It should arrive by the end of the week... I also have a transmission from an old Tamiya F-150 Ranger (Sand Scorcher / Rough Rider / Super Champ same as the re-released "Super Champ" ) I know that it has a nice 70T ![]() I will keep you all posted ![]() | |
![]() | #3 |
Quarry Creeper Join Date: Mar 2004 Location: Massachusetts
I ran the Tamiya Mammoth gearbox combo for a long time with a single Mag Mayhem and it worked very well. ![]() Stock TXT with 15tooth pinion = 34:1 Overall Crawl Ratio Stock TXT with 8tooth pinion = 63:1 Overall Crawl Ratio Mammoth Gearbox with 13tooth pinion = 91:1 Overall Crawl Ratio (2.69:1 Stock) Mammoth Gearbox with 8tooth pinion = 149:1 Overall Crawl Ratio (4.375:1 Modified) More info on the Mammoth gearbox My downloadable TXT/JUGG Ratio Spreadsheet ![]() Now i'm running the 4:1 axle gears Last edited by kona_joe; 11-16-2010 at 07:59 PM. |
![]() | #4 | |
| ![]() Quote:
Thanks for the info -- I did find you Mammoth transmission page prior to ordering the HPI gear redux box. I do not think those parts are available anymore... As I have stated.. I hope to determine the gear ration of the old F-150 ranger transmission.. I can almost bet it is better than the lousy 6.37 that the TXT-1 transmission offers due to a 65T or 70T gear that gets turned by the motor pinion! | |
