Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Yellow Truck Version III (Pics - 56K Warning)
Old 11-01-2004, 09:27 PM   #1
Default Yellow Truck Version III (Pics - 56K Warning)
I can't leave things alone, made a few more mods on the TXT.
I built a new frame aiming for the lowest possible COG. Lowered the truck & stretched the wheelbase to 16”, moved the shocks and cantilevers out to match the lengthened chassis and it’s also running the battery pack and rooster on the center skid. I’m still messing with the suspension but it's close, almost climbs like a Clod now.
Joe
kona_joe is offline   Reply With Quote
Old 11-01-2004, 09:32 PM   #2
Default Re: Yellow Truck Version III
Come on, we need more pics than that.
What rims are you running w/ the swamp dawgs, maximizers?
BARK is offline   Reply With Quote
Old 11-01-2004, 10:05 PM   #3
Diggin' the new SCX10 II!
badger's Avatar
Looks good Kona!
hmmm... battery pack on the skid... what a great idea!
badger is offline   Reply With Quote
Old 11-02-2004, 06:34 AM   #4
BARK,
Maximizers with the beautiful X75 offset plates
badger,
Yeah I like how you built your pack around the tranny, great idea!
I wanted to lower everything in the truck so I also clocked the tranny 90° and lowered the electronics. Replacing the stock frame with a new chassis allowed me to build a frame that's only 2 ¼” tall but wide enough to accommodate everything. It's a little cramped to work on but the trade off is well worth it.
Old 11-02-2004, 07:27 AM   #5
are those the jumbo swamps?
ratmloud is offline   Reply With Quote
Old 11-02-2004, 08:13 AM   #6
Kona, thanx for posting the pics. You have made me VERY happy that we did not get together for a crawl on Saturday because of the weather. I'd still be licking the wounds that your TXT would have inflicted on mine!!! No more typing, I have a whole bunch of work to do if I plan on keeping up with you!!! &*^&*^)&* I'm going to have nightmares about that stinkin' yellow body... Vince
fullmodtxt is offline   Reply With Quote
Old 11-02-2004, 09:14 AM   #7
Have you gone through any drivelines in the rear with it twisted like that
1beatjeep is offline   Reply With Quote
Old 11-02-2004, 09:16 AM   #8
Next CT Crawl ,Lets Meet Up Hear. Im Ready .
Bigbadwhitey is offline   Reply With Quote
Old 11-02-2004, 01:55 PM   #9
The longer shaft is for the rear axle, the front driveshaft is a little steep but both Revo shafts have held up fine. (knock on wood)
Cool truck! You going to bring that thing to the next New England Crawl it should be in Waterbury, CT.
Vince, Your truck is no slouch at all! Sometimes it's just slider challenged.
Joe
Old 11-02-2004, 05:56 PM   #10
MODERATOR™
EeePee's Avatar
From this point of view, it seems that if you rotate the tranny clockwise another 30 some degrees, the front driveshaft's angles wouldn't be so severe. It looks like it would line up a little better with the offset pumpkin.
Is that an option?
Nonetheless, that thing is sweet, I always liked the older one too, so clean!
EeePee is offline   Reply With Quote
Old 11-02-2004, 08:24 PM   #11
There just not enough room... You can see in this pic everything is stuffed in there tight. 8O
The angle is really not that bad, it looks worse than what it is. The Revo shafts are way stronger than the old Maxx sliders. I've had it bound up in a few tight spots where it normally would pop or twist a Maxx Slider but it didn't phase the Revo shafts.
Joe
Old 11-02-2004, 08:27 PM   #12
06 Super National Champ
JasonInAugusta's Avatar
Looks good, Joe.
This is off-subject, but are you the only crawler on the island?
JasonInAugusta is offline   Reply With Quote
Old 11-29-2004, 08:15 PM   #13
do you think you could posibly do a right up on how you rotate your tranny .... you have realy inspired me to do it
thanks
rockraper is offline   Reply With Quote
Old 11-30-2004, 03:43 PM   #14
MODERATOR™
EeePee's Avatar
And what's up with that front servo mount?
Old 11-30-2004, 04:26 PM   #15
rockraper,
The whole rotated tranny thing was a result of trying for the lowest possible COG. I figured the more weight that was positioned below the top of the tires the better. I ended up mounting the tranny this way for a couple of reasons.
• The tranny case has a funky shape, the right side is perfect for slipping a battery underneath it when rotated.
• The Mammoth reduction requires the std mag motor to be rear mounted. As for the driveshafts, since the rear shaft takes most of the abuse, it made more sense to keep it inline and offset the front.
Motor, 75% of the tranny, battery and super rooster below tire height
I removed all of the plastic tabs and mounted the tranny from the two heat sink bolts on the front of the case. There also an additional mount on the back of the tranny.
It's not pretty but it works pretty well.
Joe
Old 11-30-2004, 04:33 PM   #16
I was messing around with moving everything behind the axle, it still needs work. I’m debating on going the ¼ scale route. I keep destroying regular servos.
Joe
Old 11-30-2004, 06:24 PM   #17
Nomercy's Avatar
Default Re: Yellow Truck Version III (Pics - 56K Warning)
lookin good bro, lookin damn good
Nomercy is offline   Reply With Quote
