Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Txt-1 and Juggernaut
Thread: Gecko2 for the TXT?
Old 04-11-2004, 06:23 PM   #1
Default Gecko2 for the TXT?
It looks like the Gecko2 would work on a TXT. Would that be a worthwhile swap? This would be mostly for crawling but I'm sure I'll want to bash a bit with it too.
Mazlem is offline   Reply With Quote
Old 04-16-2004, 01:34 PM   #2
Default Re: Gecko2 for the TXT?
You would have a hard time mounting the transmission. I could take some pictures of mine if you wanna see. I have heard RCGuy is comming out with a TXT-1 chassis, but thats just what I have heard. I would just go another way then trying to mount a tranny to a Gecho2. I would fabricate your own instead of throwing down 199.00 for a Gecho2 and chopping it all up to make a tranny fit. And you will have to chop it up. Then probally decreasing its performence trying to make room for the xtra drive train components.
MicroDiladum is offline   Reply With Quote
Old 04-21-2004, 10:18 PM   #3
Anyone have a link to this "Gecko2"? What is so special about them?
BARK is offline   Reply With Quote
Old 04-23-2004, 07:55 PM   #4
The Gecko2 is a 4-link chassis for the Tamiya Clodbuster. You can find them at www.rcguy.com and www.rc4wd.com.
Old 04-24-2004, 01:06 AM   #5
The only thing that I noticed that was different between the gecko and gecko two was the bottom cnc machined links.
RcRock-Guru is offline   Reply With Quote
