11-23-2010, 05:13 PM | #1 |
Newbie Join Date: Nov 2010 Location: Currently Bashing
| Axle Gear Ratio
Im in the middle of a project and I was wondering if someone knows the correct gear ratio for the TXT-1 axle alone. I tried to compute for it and I get 2.1 : 1 but not sure if that is correct. I tried to search the forum which mostly hits only for tranny gear ratio. This make it even more confusing cause now I'm not sure how the 34 : 1 ratio will be achieve if the axle gear ratio I've computed is 2.1 : 1. Hope someone can shed some light Thanks |
11-23-2010, 11:49 PM | #2 | |
Pebble Pounder Join Date: Jun 2009 Location: Hudson, NH
11-24-2010, 05:48 AM | #3 |
Thanks for confirming this....2 project in the process of completing and this info will help a lot... |
12-03-2010, 08:05 AM | #4 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
Ya, the axle ratio is 2:1, the trans is 17:1 with 15 t pinions..
12-04-2010, 08:55 AM | #5 |
Egressor used to sell a 4:1 conversion for the diffs......I've got two sitting on my shelf in the garage! |
12-04-2010, 12:52 PM | #6 |
02-26-2011, 10:09 AM | #7 |
Newbie Join Date: Nov 2008 Location: Poland
04-10-2011, 10:00 PM | #8 |
Quarry Creeper Join Date: Jan 2004 Location: littleton
What did the reduction used to go for? I found the gears in 303 stainless with hub for $17 each for the 40t and $15 for the 12t pinion also in stainless. Both are module 1 metric gears. If someone could preceisely measure the diameter of their gears to confirm these are correct, I will post links. Nate |
04-11-2011, 09:08 AM | #9 | |
I think I paid $65 for mine | |
04-11-2011, 11:13 AM | #10 | |
If so what is your source - I would LOVE to get some! Also the diameter should be the same as others - if it is a 40t Mod 1 gear then the 40t and the Mod 1 gear specification will ensure the diameters are the same. | |
