03-22-2006, 10:10 PM | #1 |
Quarry Creeper Join Date: Jun 2005 Location: NOrthern Cali
| MFC(my first crawler)--DONE!!!!!
Hey guys, This is my first crawler,and so far,I think its going pretty O.K. Specs: Chessis:TXT-1 hacked like a mutha with custom shock mounts WB:15 1/2" Tranny/Axes:txt/txt Shocks:stock savage shocks. ESC:EVX.Had one laying around.Waiting for TR2 Servos:CS80 f/r.Waiting for those,also Wheels/Tires:40 series outbacks on 40 series reg. moabs battery mounted on axles GD600 in the mail Before I started modding the truck,I somehow managed to snap the tranny "arms",so I havent driven her in a while..Ive tried to hold it down with zipties,but no luck. Pics: Hacked chassis with custom skid Shock mounts I miscalculated on one of the mounts,so it has an extra hole Mounted on chassis Axle mounted with shocks to chassis Electronics mount Good COG Battery..Just temerary.NOT WORKING Let me know what you guys think so far..This is my first build,so I know its nothing great...Critisism is welcome if needed Thanks guys!! Btw:im only 15=) Last edited by WestCoastPJ; 04-16-2006 at 09:08 PM. |
03-22-2006, 11:47 PM | #2 |
Quarry Creeper Join Date: Apr 2004
I only think the battery inside the wheel works when you use the XTM thorn wheels, they will hold the 40's series tire, but has a little bigger of an OD. Looks good though
03-23-2006, 08:06 AM | #3 |
do you konw what size the hex is?
03-23-2006, 03:31 PM | #4 | |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
03-23-2006, 03:40 PM | #5 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
no diffrence in hexxes but the the hole on the inside is huge cuz on the x facter they have huge carrers
03-24-2006, 08:11 PM | #6 |
hey guys, I have a little problem..I took the driveshafts(revo) apart,and when I try to put them together,it has a hard time,so its not moving freely..I think its because theres air in there..Is there a way I can have it moving free again?THANKS! |
03-24-2006, 08:23 PM | #7 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
The Revo shaft's splines are "timed." Are the yokes on the female and male ends lined up? They should be, if they're not they'll bind. Moved to the TXT forum. |
03-24-2006, 09:39 PM | #8 |
THANKS BENDER! I didnt know that.haha..any suggestions for my truck? |
03-26-2006, 09:16 PM | #9 |
Are you going to add a brace between the tops of the shock towers? It would make your towers alot stronger. Mine have taken a beating from all the rollovers.
03-27-2006, 06:28 PM | #10 | |
made some links..waiting for the servos to make the drag links.. | |
03-30-2006, 07:13 PM | #11 |
Anyone know the dimensions for a 1/4 scale servo?CS-80..are they all the same?1/4 scale....Im trying to make some mounts..Thanks!
03-30-2006, 07:27 PM | #12 |
Rock Crawler Join Date: Aug 2005 Location: White Lake
Almost have the beaver done.
03-30-2006, 08:53 PM | #13 |
thats cool,but what does that ave to do with this?=)
04-01-2006, 08:15 AM | #14 |
Got some new shocks in today.Made some new shock mounts.Added cross members to the shock mounts.Wired up the battery.Still looking for a way to waterproof the batt. Any Ideas? PICS: Last edited by WestCoastPJ; 04-11-2006 at 09:29 PM. |
04-11-2006, 09:30 PM | #15 |
IM running 70 wieght shock oil all around.I might want to put the stock springs on these,since these are a little stiff,but Im not sure.Havent seen rocks yet=).What do you guys think?
04-11-2006, 11:38 PM | #16 |
Rock Crawler Join Date: Sep 2005 Location: IDK
pull the battries out en keep them in the same shape then put a shrink tube thing on is en you roe done you can put more shrinks on if ya liuke for more water resictant ps sorry for my crappy english hahah |
04-13-2006, 03:25 PM | #17 |
Pebble Pounder Join Date: Jun 2005 Location: Rockwell, NC
The ride height looks a little high but thats just me. Mabye move the shocks out to last hole on axle. Looks good though.
04-13-2006, 05:38 PM | #18 |
Newbie Join Date: May 2005 Location: P-land
Is that a battery wire going across the front of your tie rod? Seems like that might get chewed up in a hurry.
04-13-2006, 06:22 PM | #19 |
Got some parts in today: 65t lathe 1/4 scale hitec 805 BB servo(front) 1/4 scale hitec 745 BB servo(rear) OTher goodies that I can think of off the top of my head.Took me a while to make servo mounts.Say 1 hour to make the fronts!=).I dunno,ran into some roadblocks,but got her done=) yeah,the wire WAS in front.I moved it,so its on top of the link=).RIght height is a little high right now,and I might change it.So far,its been ok. |
04-13-2006, 09:25 PM | #20 |
Newbie Join Date: Apr 2006 Location: Joliet
Looks like a great build so far. When I first read the title, I thought this was going to be something related to Dane Cook (comedy)and his Car accident skit...haha Monkey F***ing a coconut....Sir is that you? Monkey f***ing a coconut? MFC?
