Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: New-buy Crawler
Old 12-06-2004, 02:08 PM   #1
Default New-buy Crawler
I just receive my new allready built crawler:
1) GD-600 gear reduction unit with 9T pinions on both input & output shafts
2) Locked f & r
3) Cut chassis & raised transmission (5.5" of center ground clearance... see Coke can)
4) battery rotated 180 so it is now in front
5) re-located links (15.25" wheelbase)
6) T/E-Maxx driveshafts, to make # 5 possible
7) LONG aftermarket shocks with metal bodies & threaded pre-load adjusters
'Cut-n Shut' Jumbo Kongs (3.25" wide, 7.75" tall) w/ narrowed Twin Force wheels and 1/2 lb. of BB's in each front tire
9) Hi Tec FM Tx & Rx, (1) 645MG servo (2ws), ROOSTER ESC, 1500 battery, single Trinity motor (Speed Gems2)
I just bought 3000 batt and I only have 25 min runtime...
Should I put 2x3000 batts?
Should I put a better motor?
Can I put more gear reduction?
spider is offline   Reply With Quote
Old 12-06-2004, 02:15 PM   #2
TRD
Default Re: New-buy Crawler
YA wa we all saw it on EBAY. i will buy the kongs but thats it
TRD is offline   Reply With Quote
Old 12-06-2004, 02:17 PM   #3
What kind of rig?
Turd; I don't think he is selling it?
30 minutes of run time is pretty average. Don't worry about the extra battery. Lathe motors will give you great run time, so will lots of reduction.
SR5Dave is offline   Reply With Quote
Old 12-06-2004, 02:24 PM   #4
A Tamiya TXT-1. Here are some pics:
http://www.printroom.com/ViewAlbum.a...lbum_id=190846
It is written speed gems2 on the motor..? Is it a good motor? So I should no put 2x3000 batt pack? Won't it help a little?
Old 12-06-2004, 02:27 PM   #5
TRD
SR5
it is a txt that was on ebay, someone posted pics on the form. it looked cool the guy that built it is a member . i want the kongs if he sells them, just putting it out there. cool
Old 12-06-2004, 02:31 PM   #6
I just receive it from UPS, and yes it was on ebay. I think I should keep the kongs if I want wheels under it :? ... To bad it's not 4ws... I plan doiing it soon. What will I need? wich servo? Remote? wiriing?
Old 12-06-2004, 03:05 PM   #7
How does a TXT do with kongs? I'd think you would want a wider axle than that...
Old 12-06-2004, 03:22 PM   #8
30min. run time is BAD get a magnetic mayhems motor and run the gd-600 with a 15t and off the motor run a 3.8. your run time should get to about 45 min to 1 1/4 hr.
1beatjeep is online now   Reply With Quote
Old 12-06-2004, 03:39 PM   #9
Also run a rx battery. and ditch the stock servo guard. Those things are gay! You might think about lowering the truck to around 4-4.5" of center clearence. It will help how much it rolls over. I've got 3.75" of CC and love it.
rckjeep is offline   Reply With Quote
Old 12-06-2004, 03:54 PM   #10
Sorry for my ignorance but what are magnetic mayhems motor and rx battery?
Old 12-06-2004, 04:45 PM   #11
kyosho magnetic mayhem it is a motor that some people run on there crawler. the r/x batt. is something to help you run big servos.
Old 12-06-2004, 06:32 PM   #12
It seems like my 645MG servo is not enough... I have a ridiculous turning radius :( . How much would be enough to turn Jumbo Kongs?
Old 12-06-2004, 06:52 PM   #13
i use hitec hs-5745 it has about 250 tork and the hs-5735 is 265 of tork.but i dont know if they would work on a txt axle i use mine on xfator axle.you have a pm/messages to.
Old 12-06-2004, 06:53 PM   #14
Can I add stroke to the servo? It seems like the servo don't have enough stroke for the steering arm. With no power on the servo have plenty of stroke but as soon as the power is back I dont have enough stroke even with no weight on....?????
Old 12-06-2004, 07:04 PM   #15
spider push your message spot on the top of this page
Old 12-06-2004, 11:32 PM   #16
Diggin' the new SCX10 II!
badger's Avatar
Spider,
If you don't know what that means like most of us then just click this link to go to your private messages.
http://www.rccrawler.com/modules.php...ivate_Messages
badger is offline   Reply With Quote
