![]() | #41 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
Hi Do you have any clearence problems against your bottom links with those bead-locks. i have some of these beadlocks and theye have alot of offset. i am waiting to get some 12mm to 23mm wheel adaptors for these wheels. Or are those wheels narrowed? Thanks james |
![]() | #42 |
Rock Crawler Join Date: May 2006 Location: san diego
Hey. No clearance issues at all. The wheels are plane jane stock. But I do have RC4Wd 23mm adapters, and these add width. I fixed the drive shaft and figured out a way to make them stronger. By filling the center with a screw. When the shafts twist I noticed they squish into the center void allowing the twist. So filling the void with a solid should greatly aid against twist. Of course then the end of the (male shaft I was using) just snaps. So I made two more sets with female ends. I think That should be a little stronger. I installed one and zip tied the other to the body. I drove today and was about to go through a whole pack with out breaking anything. When I noticed the lower front four bar was hanging down. It pulled out from the threaded end on the chassis side. Oh well. Gotta keep the streek going ya know. JK. I will try JB weld on that and see how it goes. wish me luck Last edited by The Muscle; 11-27-2006 at 08:33 PM. |
![]() | #43 |
so far the JB weld repair on the stripped threads is holding up ![]() next up is independent 4ws. the full time 4ws gets in the way crawling techy stuff. though it is fine for freestylling. which is what I use this rig for most the time anyway. Last edited by The Muscle; 12-19-2006 at 03:57 PM. |
![]() | #44 |
RCC Addict Join Date: Dec 2006 Location: Flatwoods
Nice truck you have there. Good luck on running it with out breaking something. It seems I break something every time I go crawling. lol
