![]() | #1 |
Rock Crawler Join Date: May 2006 Location: san diego
| ![]() ![]() what you`s think a my truck? ![]() |
![]() | #2 |
Quarry Creeper Join Date: Feb 2006 Location: Tweaking my shaft
It looks good. How about some specs? WB, shocks, motor, gearin, etc.
![]() | #3 |
Quarry Creeper Join Date: Feb 2006 Location: Angier N.C.
Ok, I'll bite. Why bad luck? Looks pretty good to me. ![]() |
![]() | #4 | |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
| ![]() Quote:
I think you should learn the English language, then worry about what we ' s think a your truck. ![]() | |
![]() | #5 |
novak hv-maxx:motor 17 inch :WB txt tranny gd-600 rc4wd :drive shafts rc4wd ;links XTM X factor :shocks has any one made a rc rock racer? would it have less articulation? maybe anti sway bars? what do y-all think is that english? ![]() |
![]() | #6 |
oh yea, truck not done yet. name is because i'm working on paint scheme of new body,thinking #13 on roof an doors, so bad luck seemed to fit, :-P also since i`ve had this truck since dec 05 and drove it only two packs before breaking axle and been rebuilding and modding since and waiting for parts, learning a lot surfing this forum though.
![]() | #7 |
Pebble Pounder Join Date: Jul 2005 Location: Greece
I have a TXT Crawler and a TXT racer. They are two completely different configurations. The racer is run in monster jam type competition. The racer uses stiff sway bars, is lowered to the legal limit, dual 17t motors (class limit, there is an unlimited class that allows any non brushless motor), heavy oil in shock, short wheel base for tight steering with out using rear steer (rear steer = roll over at high speed), uncut tires for carpet and a wheelie bar for when I get to throttle happy ![]() |
![]() | #8 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
tk he was talking about a rock racer im building one out of a tlt and im going with some stifferr shocks and a sway bar set up for it
![]() | #9 |
Hi. This is an older photo of "Bad Luck" there have been a few changes made since then. The shocks have been repositioned. With custom shock towers on the chassis, and mounted on lower links pushed all the way to end of link. I also cut the tranny, lowered it in the chassis 1/2 inch.(this lowered the cog and raised the GC) ![]() New wheels and tires, Proline moab XLs beadlocks 7 inches. Chopped up the chassis, more off the bottom and both ends for better shock clearance. I've totally removed the body mounts, and lowered the body. and shortened the wheel base to 16 inches. I will have some photos on monday. I'm still waiting for my rc4wd punisher shafts.The first set I broke in 15 seconds never leaving my bedroom. They were kind enough to replace those shafts with ones with stronger pins, but I broke them also. at least I was able to make one pass of my rock garden. but when I tried to pull a wheelie, snapolla. So the new, totally redesigned shafts should be arriving at my door and day,week,month. soon hopefully. Then i can give "Bad Luck" a test run. stay tuned for future updates. ![]() |
![]() | #10 |
this shot you can see no steering links in front of the front axle also motor center in chassis.and home made servo mount. ![]() looking from under, see lower tranny support? ![]() top view ![]() home made BTA steering, 5955 servo ![]() flex shot. ![]() front shock towers. ![]() rear shock towers. ![]() |
![]() | #11 |
body slammed on pancaked chassis ![]() Bad Luck has not seen the real world yet. ![]() |
![]() | #12 |
Moderator ![]() Join Date: Apr 2004 Location: In my head
Looks good! How do you like the brushless with the GD-600??? What's the wheelspeed like? Too fast, enough power (probably stupid question), will it go slow enough to crawl???
![]() | #13 |
I have no idea. Without the GD-600 it was to fast for serious crawling. About 20 - 25 MPH. I'm still waiting for driveshafts. |
![]() | #14 |
O.K. rc4wd is totally lagging on the punisher shafts. does any body know what other options i have. as far as other drive shafts to work with stock txt tranny and axle. thank you for not replying with "search"
![]() | #15 |
Rock Crawler Join Date: Dec 2004 Location: Grand Forks, ND
well use search but i will give you what to search for revo shafts will work but you have to modify a bit first |
![]() | #16 |
RCC Addict Join Date: Jun 2004 Location: Bruiser Heaven!!!!
the revo shafts will work on your txt with a little drilling and grinding. and here is the link to help alittle. I've seen lots of posts asking about Revo shafts... rich |
![]() | #17 |
Thanks for the 411 on the drive shafts.I tried the search thing and it was cool. But any way I ended up putting maxx shafts on. They seem like they were made for the txt. I also have buttoned up the GD-600, spur gear, tranny, situation. all that is left to do before driving is to install a receiver. hope to have pics for you all can see soon. ![]() |
![]() | #18 |
Quarry Creeper Join Date: Jun 2005 Location: DH
Pictures you took of your truck looks good. As far as drive shafts, the revos is probably the best ones to use/ or to have.IMO Make me wanna get another TXT ![]() |
![]() | #19 |
Nope.. ![]() Join Date: Aug 2005 Location: Whiteland, Indiana
That HV-maxx is gonna EAT those Maxx shafts.
![]() | #20 | |
Rock Crawler Join Date: Jan 2005 Location: Nanakuli
| ![]() Quote:
