Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Buildin a Bronco
Old 10-01-2011, 05:26 PM   #41
Originally Posted by Mazlem View Post
Ok, got the electronics secured and programmed. It's not waterproof but should provide plenty of protection. Can't crawl anywhere right now tho cause the weather sucks.
Maz,
Do you think that is going to get too hot in there for the ESC??
CraZySteve is offline   Reply With Quote
Old 10-01-2011, 09:56 PM   #42
Probably not, being in a crawler. The holes for the cables will let in air, an I cut two slits in the cover to let warm/hot air out. I think that'll be ok.
Mazlem is offline   Reply With Quote
Old 10-02-2011, 03:18 PM   #43
Did some tooling around the house an decided the shocks needed more work. It now has 80wt in the right-rear and left-front, with 60WT in the others. Also stood the shocks up a bit. The suspension still feels a bit soft, but we'll see how it handles if the sun ever comes back.
Here's mandatory flex shot #3!
Old 10-13-2011, 07:56 PM   #44
The front now has CVD's and alum knuckles.
Had to bend the tie rod just a little to clear the diff, an now I need a longer servo horn to really take advantage of all that. Pics will come when the servo horn does.
Old 10-19-2011, 10:03 PM   #45
Got a new motor! It's a HolmesHobbies Torquemaster pro 45T. I'm gonna try a 9T on the motor with no GD600. Also went back to one battery in the chassis like it was originally.
Old 10-24-2011, 09:17 AM   #46
And the rear lockout:
Is this done because it is a steering axle but you won't have RWS?
Rob Cote is offline   Reply With Quote
Old 10-24-2011, 09:53 AM   #47
Yep. This way if I ever do want to add rear-steering I just need to swap the tie rod.
Old 11-06-2011, 02:29 PM   #48
Here's a shot of the CVD's and wideners. The front is 1" wider than the rear now.
Got a new Hitec 7955 installed with a longer horn:
An here's a couple shots of the steering at full lock. The front of the front axle is now the steering stop for each side.
