Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: whats the wheel base of F350
Old 10-18-2011, 11:35 PM   #1
Default whats the wheel base of F350
I am curious as to the juggernaut 2 F350 body wheel base thanks in advance
benzoel is offline   Reply With Quote
Old 10-19-2011, 10:50 AM   #2
Dunno if it helps, but I saw in a couple other forums that the only difference between the F350 and standard Jugg body is the wheel wells, so if you can find specs for one it should be the same for both.
Mazlem is offline   Reply With Quote
Old 10-20-2011, 08:34 AM   #3
Ok ill look thanks
Old 10-22-2011, 08:46 AM   #4
The w/b on my F350 is 282mm
Cortina79 is offline   Reply With Quote
