01-05-2005, 02:04 AM | #41 |
Guest
Posts: n/a
| Re: Roid V4
badger, nice rig have you had any trouble with torque roll, thats the main obstacle im trying to tackle right now with the rockeater let me know if you got any suggestions -Chris |
01-05-2005, 11:19 AM | #42 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: Roid V4 Quote:
I think there are 3 major things that help eliminate torqe roll. 1. Shock positioning and spring rate's used. 2. Link triangulation, mounting positions of the links. 3. (As Dirk recently mentioned) Low gearing, use a gear reduction and/or and lathe motor. I am completly done with my TXT suspension. I might change the shocks to slightly longer ones just to get a little more center clearance but if they do not work as well as the Integy shock/springs I am using then I will go back. Last night I took out the mammoth gear reduction and I am installing a GD-600 just to see if there is big difference. | |
01-18-2005, 08:18 PM | #43 |
Pebble Pounder Join Date: Dec 2004 Location: Delaware A Place With No Rocks!
| Re: Roid V4
Your truck has been a huge part of the build of my txt and just wanted to say i love your truck and website keep crawling i know i will.
01-19-2005, 08:29 AM | #44 | |
| Re: Roid V4 Quote:
