![]() | #1 |
Rock Crawler Join Date: Dec 2004 Location: Grand Forks, ND
im sure this question has been asked before. but how much (about) would it cost to order the parts to build some txt axles. i have seen clod axle kits on rc4wd for 130 so i figure it shouldnt be much more than that. im sure somebody on here has done it. so a price would be okay. and so would the proper part numbers. or if u dont have pn's a site to buy the stuff from or a site to find out. thanx fuzz |
![]() | #2 |
well i think i found the necessary parts to build jugg/txt axles http://www2.towerhobbies.com/cgi-bin...LXUR43&P=K http://www2.towerhobbies.com/cgi-bin...LXUR37&P=K http://www2.towerhobbies.com/cgi-bin...LXUR36&P=K by the looks of it i could assemble to complete jugg/txt axles out of that. by the way jugg axles are the exact same as txt axles right? |
![]() | #3 |
2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Big Bear Lake
As far as I can tell you will also need: metal stub axles (4) part # 9805805 metal drive hexes for stub axles/wheel nuts (4 each) #9465586 outer plastic knuckles (4) #0005296 there's also a set of gears that loads into top of axles not sure of part# need to fab brackets to mount links and shocks to axle some type of steering servo mount because stock mount hangs too low last 2 part #'s you listed, you need two of each i think that's it? but im not sure if it's worth it, by the time you add all this up what tranny are you going to run? |
![]() | #4 |
Pebble Pounder Join Date: May 2004 Location: east coast
i would bye them off e-bay matt |
![]() | #5 | |
Diggin' the new SCX10 II! ![]() ![]() ![]() Join Date: Mar 2004 Location: Norcal
| ![]() Quote:
![]() | #6 |
emaxx or stampede. probably stampede. depends on how it all falls together. and ill pretty much go for anything cheaper than a txt-1 which i can get for 322.98
