![]() | #1 |
Powered by Awesome ![]() Join Date: Sep 2004 Location: Parker, Colorado
I've been talking about posting this for a while and here we go... here is the progression up to what i have now... Here are the old pics: ![]() ![]() ![]() ![]() ![]() And after throwing stuff and trying to figure out the suspension... here is where it sits now. I am still waiting on 2 6mm ball nuts, double sided tape (nevermind the zip ties), and i still have to turn down the shaft on my gd600... agian: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() yeah... that should probubly be more then enough..... Sorry about the blurry pics, cheap camera. iff you notice, i mounted the spings to the canti's so i can rotate the mounting points to adjust the angle of the shocks so i can get her dialed in..... |
![]() | #2 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
try this. put your shocks in your stock cataleaver holes it would help alot
![]() | #3 |
i actually left the stock canti holes there ready to use but it sat way to tall and did not have that great of articulation... once i get the gd600 done i am going to play with different setups, has anyone else tried using the savage shocks on a txt to the old canti holes? pics come in handy... ![]() |
![]() | #4 |
2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Big Bear Lake
I didn't have much luck mounting savage shocks to stock chassis, I had to build custom mounts for it to work right. I also thought about cutting bump stops(rubber tubes), but, I noticed plunger inside shock will hit shock cap at full compression. At least that's what I noticed w/ Hot Bodies savage shocks. Go to TXT talk and click on ROCTAPUS, if I had any computer skills I would have put link here, for pics of my set-up. |
![]() | #5 |
Quarry Creeper ![]() Join Date: Jul 2004 Location: Elizabeth City NC
skidplate..............
![]() | #6 |
Newbie Join Date: Jan 2005 Location: ooltewah
thats an awesome truck dude. what is the length of those shocks?
![]() | #7 |
i have run savage shocks on the txt also had to make brakets also. it work very well also with the shocks
![]() | #8 |
Rock Crawler Join Date: Jul 2004 Location: Mt.View CA
I see that your servo seems to be close or past the front tires,which that thing is going to get killed on a rock when climbing a steep face.
![]() | #9 |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
BRs right, you'll have a rough time with that thing way out there.
