Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: my txt-1 build
Old 11-06-2012, 10:35 PM   #1
Default my txt-1 build
i dont know why but i can never have anything stock i always have to build or mod something so i ended up getting a tamiya txt-1 in a swap
its a cool truck but it was missing something
well i end up finding a new bright cxt truck body and well here we go again
td-civ is offline   Reply With Quote
Old 11-07-2012, 05:47 PM   #2
Default Re: my txt-1 build
That will be a monster when its done! I'm looking forward to seeing it done.
dont slow down is offline   Reply With Quote
Old 11-08-2012, 07:49 PM   #3
Nice! I will be following this one! Looks like you are on your way! Just extend the 4links equally front to back and you should be good! What is the wheelbase of the CXT Body? Looks about 20 inches or so...
CraZySteve is offline   Reply With Quote
Old 11-08-2012, 11:53 PM   #4
thanks guys i cant wait till its done too as for the wheelbase i dont know ill check it and let you guys know
here are the plans for this build
new custom built chassis
2 txt-1 trannys yes im running 2 lol
4 tekin 55 turn motors
2 tekin fx-r pro
3 Savox sa-1230sg 2 for steering one for the tilt box
and over 40 leds
ok just so you guys know why im running twin trannys and 4 motors is becasue i want pull a full size car with it lol the axles will be built up with steal spools and aluminum housing
but 90% of the time it will just sit on the shelf looking good
Old 11-09-2012, 07:27 AM   #5
2 tekin fx-r pro
and over 40 leds
That is very ambitious! You will have to had alot of weight to that rig just to allow it enough traction to pull a 3000lb vehicle!
Old 11-10-2012, 10:27 AM   #6
its all out of fun
plus the lipos are 4 3s lipos
my txt-1 build - Similar Threads
My TXT Build JeremyH Tamiya Txt-1 and Juggernaut 46 05-30-2007 07:08 AM
New 2.2 txt build MatrixTech Tamiya Txt-1 and Juggernaut 12 04-15-2007 03:56 AM
New Txt Build rockbender Tamiya Txt-1 and Juggernaut 2 01-25-2007 07:24 PM
first txt build Rock Logic Tamiya Txt-1 and Juggernaut 4 09-28-2006 12:13 PM
TXT Build up FrankyRizzo Tamiya Txt-1 and Juggernaut 15 06-29-2005 02:44 PM
