Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Txt-1 and Juggernaut
Thread: My TXT 4TO1 MOD
Old 12-26-2012, 10:40 AM   #1
RC tinker's Avatar
Default My TXT 4TO1 MOD
Hi ,here is my 4to1 mod ,
made with hobby store parts ,
you can keep the diff action for
turns at speed this is all the parts
that you will need to buy,....
.I first took part the diff and mounted the gear
side in the drill press ,make sure that the gear is
centerd ,my drill press is a 5 speed ,I ran it in
the 3rd position
here is were most may not have the tools ,
I used a very small belt grinder , the 1 inch wide
size to grind off the stock teeth ,just down enough
to clear the spur gear ....
Click the image to open in full size. ,
ok now ,I used a cone shape hole grinder
i picked up at habor freight tools to inlarge
and center the center hole ,the cone shape
will keep in centerd ,you do not want the gear
to be lobing up and down as it turns
take your time with this , use the proper drill and tap
,you do not want the srews you use to be lose ,
use the gear to mark the gear mounting holes
,I used 3mm,
Click the image to open in full size.,
now it`s time to be very patient with the
grinding of the housing ,I had burned though
lightly in a couple of spots on the frist one
,none on the second ,grind some and test fit
,repeat as needed ,you will need to do
both top and bottom
now it is time to do the pinion , again grind
little and repeatly test fit ,yes you will grind
into the set screw hole , I used red lock tight
then used the dremel to grind down the set screw ,
always test as you go , this is may first
time tring to do an artical and pictures
,so any help on doing it better ,or any
questions please let me know . late
r this week i hope to be able to have
time to test them out [/LEFT]
RC tinker is offline   Reply With Quote
Old 01-02-2013, 08:10 AM   #2
RC tinker's Avatar
Default Re: My TXT 4TO1 MOD
well after the 5th 5000mah 8.4 pack i lost both axles ,but wait , the 3mm screws i used in the diff worked there way out ,i know i should of use lock tight , fixed this and did noticed one of the set screws tilting a little ,so i compared very closly to the other one ,the one that was tilted was in the rear and it was ground a little more , so sunday i went and picked up another pinion and re-did this one , i just ran the 5th pack again still running ,still waiting on the e-mail from the gear rod company, i think i will try sending another Click the image to open in full size.
Old 01-02-2013, 08:56 AM   #3
666
Searching
666's Avatar
Better pictures would be nice, try adjusting your macro features on your camera?
666 is offline   Reply With Quote
Old 01-09-2013, 03:37 PM   #4
You had me going until I saw the partial pinion in place. I don't think that is going to hold up to serious abuse.
Is there room to drill/tap a new hole at 90 degrees from the original, just further up the pinion. Even if you had to "clearance" a tooth or two to make it work you'd be better off than what you currently had. Heck, drill all the way through and double up on the setscrews.
I don't know how rare/expensive the shaft is, but another option I'd seriously consider is welding the gear to the shaft.
What is the stock ratio between the ring and pinion? And the stock lower gears?
And, yeah, we want better pics.
meatmonkey is offline   Reply With Quote
Old 01-13-2013, 02:23 PM   #5
some where around 2:1 on the stock gear ratio, I had the egressor kit on one of mine, but I didnt like dremeling out so much of the housing....
badBKO is offline   Reply With Quote
My TXT 4TO1 MOD - Similar Threads
TXT-1 Chassis Mod, step by step dont slow down Tamiya Txt-1 and Juggernaut 32 10-25-2012 04:13 PM
my txt 4:1 gear mod leemegon Tamiya Txt-1 and Juggernaut 3 11-23-2010 11:43 PM
TXT / Jugg 2 4:1 gear mod blowout EGRESSor Tamiya Txt-1 and Juggernaut 13 11-22-2009 10:27 PM
txt with super rooster and tq3 with rear steer mod on ebay tmaxxking1 Chit Chat 0 03-27-2007 07:12 PM
Front Dig Mod,steering mod & pushbar TheButcher69 General Crawlers 1 11-06-2006 06:32 PM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
