Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Txt-1 and Juggernaut
Thread: TXT-1 Fans.
Old 05-06-2004, 08:08 PM   #1
Default TXT-1 Fans.
Hi guys,
Please take a minute and tell me what you think the TXT-1 would benifit from
Is it lacking in articulation, too top heavy, wheelbase too short, weight an issue, wasted torque, not fast enough, turning need more radious
The TXT-1 is the best crawling truck out of box ever made, most people still prefer the looks of the juggernaut but the suspension of the TXT-1.
Would a half tubed TXT-1 be of interest
An expensive chassis with outragous suspension
A TXT with the tranny gearcases moved 2/3rds forward
A single motor replacement that outperforms the stock pair and lessons the weight.
Simple kit with longer links and softer springs
What can we do to this sweet ride
Throw out some ideas, I don't own one of these awesome trucks yet. I am going to buy one when I can, so give me some ideas. I really like the stock ladder chassis and scale driveshafts.
If anyone has an idea post it, no matter how silly it seems..... :P
skoolbus is offline   Reply With Quote
Old 05-06-2004, 08:52 PM   #2
Default Re: TXT-1 Fans.
Originally Posted by skoolbus
Hi guys,
Plenty of articulation, it is top heavy, 14”-15” better, weight no big deal, needs to be slower, trim the knuckles for improved turning radius
No, not really
An expensive chassis with outrageous suspension
Not needed
Possible but moving the battery & electronics to the front of the truck helps offset the weight
Mammoth Reduction Gearbox with Mag Mayhem
Longer Links with better quality shocks
Lengthen the wheelbase, Lower the C.O.G., Gear it down, Trim the tranny and frame for improved Break over Angle.
Joe
Hacked up TXT owner
kona_joe is offline   Reply With Quote
Old 05-06-2004, 10:04 PM   #3
31st place in 2006 Nats!!
toyofast's Avatar
A stock TXT with very very minor tweaking can have to MUCH articulation...
Stock TXT-1, locked diffs and Kyosho ball-ends on links everythig else basicly stock:
This TXT crawls very well! It'll go a bit past 90* articulation and it has a trick feature to raise and lower the front end for going up really steep climbs.... I can't let the secret out on how it works
A TXT with a reduction unit, a single Mag Mayhem, locked diffs, high torque servo(s) and properly placed links can go many many places. It's a great platform for building a crawler.
toyofast is offline   Reply With Quote
Old 05-06-2004, 11:34 PM   #4
These Oregon pictures are really starting to get to me..First sandy beaches, now a stream with rocks and green moss growing everywhere...... 8O
I think those txt's need longer links and a battery relocation, maybe to the front and a bit lower, yet still out of site.
Old 05-07-2004, 07:10 AM   #5
Lock Diffs, 15" wheel base, Narrower Tyres, Relocated Servo's, Upsidedown Tranny, 8 Shock setup = Clod competitive climbing ability with no torque twist.
Definately great out of the box but still have heaps that can be done.
TXTFUN is offline   Reply With Quote
Old 05-07-2004, 07:20 AM   #6
Toyofast, anyway you can post up some more info on that TXT. Or is the owner on this board? I am already planning to have the front move up and down on mine, and I think he may use the same set-up I will be using. I am slowing getting mine together, and things should go a lot fast now that school is not in the way
bustedcrawler is offline   Reply With Quote
Old 05-07-2004, 10:04 AM   #7
I think the most important things you can do to a TXT is,
1. lower the ride hight.
2. Cut the chasis for center clearance, 5 inch minimum
3. Remove servo gaurds and convert to conventional steering
4. Lock diffs
5. move weight forward, ie. batteries, elecs.
6. extend wheel base and use larger, narrower tires.
7. see article on home page
DirkDigler is offline   Reply With Quote
Old 05-18-2004, 11:41 PM   #8
Did you trim the small cylinders that act as steering stops or did you trim something else on the knuckles.
I was contemplating on triming the steering stop cylinders but Im not sure what kind of stress that would put on the "u-joints" a the knuckle. Do you have or can you get some pics of what you trimed/cut off.
BARK is offline   Reply With Quote
Old 05-24-2004, 03:54 PM   #9
hey toyofast, i live in portland, we should go crawling sometime, you must show me some of these spots!!!
jordanator62 is offline   Reply With Quote
