10-09-2006, 10:05 PM | #21 | |
Quarry Creeper Join Date: Jun 2005 Location: Flagstaff
Did not mean to afend when I was asking if anyone thought this post should get a sticky. | |
10-09-2006, 10:08 PM | #22 |
Pebble Pounder Join Date: Jun 2005 Location: Peoria, AZ
Great write up Don!! I just might have to try it.
10-09-2006, 10:14 PM | #23 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
NP this should be added to the how to build a TXT sticky, its about the only original idea on the txt forum | |
10-09-2006, 10:45 PM | #24 |
Where is the rear brake?
10-09-2006, 10:55 PM | #25 | |
10-09-2006, 11:35 PM | #26 |
OK I see now. So it pushes this gear away from the pinion and locks the gear at the same time.
10-09-2006, 11:37 PM | #27 | |
simple is a good thing | |
10-10-2006, 10:08 AM | #28 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
I like the idea behind this... I might have to try this over the winter months.
10-10-2006, 11:01 AM | #29 |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
Looks like a great idea. Do you think there will be any problem with the splined shaft over time stripping out? How smoothly does it engage and disengage? |
10-10-2006, 11:04 AM | #30 |
Quarry Creeper Join Date: Jan 2005 Location: Milan, Italy
You are a genius!!!!!! THANKS |
10-10-2006, 11:28 AM | #31 | |
It depends on how smooth your servo is and on if your axle is under a load when you disengage it. If it is under a load you mite get a clik from the diff once you hit the throttle. The clik is the arm locking in the teeth of the bevel gear. | |
10-10-2006, 12:22 PM | #32 | |
10-10-2006, 12:55 PM | #33 | |
Yes. | |
10-10-2006, 02:35 PM | #34 | |
10-10-2006, 03:09 PM | #35 |
I just think it's cool to be able to help the people on this site and the crawler hobbie.
10-10-2006, 03:47 PM | #36 |
Rock Stacker Join Date: Oct 2005 Location: Bedford
It really should get sticky..... It's a great mod that looks stock. Is this instead of rear steer or in addition to rear steer? If it is instead then how well does it do compared to rear steer?
10-10-2006, 04:35 PM | #37 | |
unless you run a 6 channel radio then you have both front and rear dig and front and rear steering........ | |
10-11-2006, 04:23 AM | #38 | |
IMO this should be done to both front and rear axles with front and rear steer. Thats how my truck is. | |
10-11-2006, 09:32 AM | #39 |
Moderator Join Date: Apr 2004 Location: In my head
Great job!!!
10-11-2006, 12:25 PM | #40 |
Great idea Don! Someday () when my TXT axles are rolling they will have this mod.
