Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Basic TXT build up
Old 10-30-2005, 11:52 AM   #1
MODERATOR™
EeePee's Avatar
Arrow Basic TXT build up
Very simple, easy to do modifications. The pictures pretty much explain it all. The front servo mount is the basic type, I recommend using three screws, the rear one is good for support. I used cross braces to hold the tranny in place, but just the two top screws to actually hold it in place. The shocks use two different springs. Right rear and left front are stiffer with 80 weight oil, and the other two shocks use 40 weight. Torque twist is very minimal.
The only items purchased other than the truck were the motor, and GD 600, and the borrowed softer springs. Everything else has been recycled from the original kit. Oh, and the wheels and tires, oh, and the Maxx 2.5 driveshafts.
This is a good basic TXT crawler.
EeePee is offline   Reply With Quote
Old 10-30-2005, 11:57 AM   #2
MODERATOR™
EeePee's Avatar
And now Imageshack took a dump...
Old 10-30-2005, 01:25 PM   #3
MODERATOR™
EeePee's Avatar
Imageshack is back, here's the other two pictures I was going to post:
Just something to look at.
Old 10-30-2005, 06:41 PM   #4
Sweet, and Welcome to the our little side of the crawling commuity.
Seriously though. Nice job. I would recommend replacing some of the cross braces to the chassis to stiffen it up.
mike is offline   Reply With Quote
Old 10-31-2005, 08:53 PM   #5
MODERATOR™
EeePee's Avatar
Close ups of the transmission braces.
Old 10-31-2005, 09:22 PM   #6
Mmmm, that sandwich looks good. Looks like steak and onions and stuff.
This is a good little bit of info. Looks to me like a sticky might be coming along.
Peace
harris
Harris is offline   Reply With Quote
Old 10-31-2005, 10:39 PM   #7
2006 2.2 National Champ
BENDER's Avatar
Exclamation
Stickied, good post EeePee!!
BENDER is offline   Reply With Quote
Old 11-01-2005, 04:30 AM   #8
MODERATOR™
EeePee's Avatar
Sweet, thanks guys.
Old 11-01-2005, 02:48 PM   #9
MODERATOR™
EeePee's Avatar
Here's some wheel width comparisons.
TXT stub axles and narrowed stock TXT wheels.
Old 11-01-2005, 02:49 PM   #10
MODERATOR™
EeePee's Avatar
Clod stub axles and uncut Clod wheels.
Old 11-01-2005, 02:50 PM   #11
MODERATOR™
EeePee's Avatar
TXT stub axles and Proline's Outback 40 series wheels.
Old 11-01-2005, 02:51 PM   #12
MODERATOR™
EeePee's Avatar
Clod stub axles and Heydco's Maxx wheel adapters with normal offset Proline Velocity wheels.
Old 11-01-2005, 02:53 PM   #13
MODERATOR™
EeePee's Avatar
Clod stub axles and Heydco's Maxx wheel adapters with wide offset Proline Velocity wheels.
Old 11-01-2005, 04:23 PM   #14
MODERATOR™
EeePee's Avatar
The threads on the shock shaft have the same pitch as the cantilever links, or rods, or whatever from the stock suspension. So I used the ball end from that, and used the longer threaded ball studs from the steering set up. The other side of the shock still uses the brass sleeve and screw from the original mounting spot.
Old 11-14-2005, 04:54 PM   #15
MODERATOR™
EeePee's Avatar
Proline Maxx Masher tires on Maximizer 5 hole (normal offset) wheels, with Thunder Tech wheel adapters. Heydco adapters are ~1/16th of an inch wider.
Old 11-17-2005, 02:24 PM   #16
That is a nice build up.
RCCasper is offline   Reply With Quote
Old 11-17-2005, 03:04 PM   #17
MODERATOR™
EeePee's Avatar
Why thank ya!
I switched over to a single 55 turn lathe motor with a 9 tooth pinion gear. With Sub C 3300s hanging out in the middle area of the truck for a central balance, it does pretty good on the late fall park drives. But it's pretty slow and the Mashers don't clear dirt very well, but they still work all packed up full of junk. Balances on it's side even with the batteries where they are, and the small tires.
Old 11-17-2005, 07:04 PM   #18
PapaGriz Yo
Grizzly4x4's Avatar
Great job EeePee!
Thanks for doing that, I'm sure this will be very helpful to alot of people.
Grizzly4x4 is offline   Reply With Quote
Old 11-18-2005, 08:52 AM   #19
Whats the wheel base?
Crawler80 is offline   Reply With Quote
Old 11-18-2005, 11:07 AM   #20
Colt Python/SR9c
TwistedCreations's Avatar
i think he is around 15 1/2- 16"
TwistedCreations is offline   Reply With Quote
