01-17-2005, 12:04 PM | #1 |
Pebble Pounder Join Date: Sep 2004 Location: Phoenix
| xfactor vs txt axels?
Is the x wider than the txt? would the swap be a good idea and anything I should look out for before getting started?
01-18-2005, 01:58 PM | #2 |
I wanna be Dave Join Date: Jan 2004
| Re: xfactor vs txt axels?
much wider. I take it that you are wanting to swap Xaxles in for TXT axles? Check out the Digler if you want info on doing that swap. |
01-19-2005, 10:18 PM | #3 |
cool thanks. I am planing on doing the swap so all the info i can get helps alot. Thanks |
01-19-2005, 11:19 PM | #4 |
Quarry Creeper Join Date: Jun 2004 Location: Ventura
you can offset the wheels enough so that they are the same width, but the x-f axles will have better steering, because the knuckle pivots near, if not on the center-line of the wheel. The x-f axles also have lower gearing than the txt axles. For doing a swap you should also buy bft pinions so you can bolt on drive shafts that fit the txt.
01-25-2005, 09:38 AM | #5 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
you will be so much happier with x-factor axels
