![]() | #1 |
Newbie Join Date: Nov 2005 Location: palm springs
Would the stock tranny good for crawling,I going to put 9 Tooth Pinion with a 55turn motor.How good is this crawler http://www.rccrawler.com/20txt.htm |
![]() | #2 |
Rock Crawler Join Date: May 2006 Location: san diego
Stock tranny is a good one for crawling and is used by many here on this site. and that crawler is a very good base to begin from. That was my first insperation, and my truck has evolved only a little from that platform.
![]() | #3 |
How do you mount the links on top of the axle,is there a bracket
![]() | #4 |
Quarry Creeper Join Date: Oct 2006 Location: Amsterdamned
Most people here seem to fabrik those brackets themselves from what I see ...
![]() | #5 |
Quarry Creeper Join Date: Jan 2006 Location: colchester
there are two posts that have screws that go into them. that is how you attach the upper links. use the stickies in this section to guide you. thats what i did
![]() | #6 |
Would a,9 Tooth Pinion with a 55turn motor be to low for crawling???? I think I'm going to get Axiom motors for it. |
![]() | #7 |
Quarry Creeper Join Date: Dec 2005 Location: United Kingdom
My Son has a TXT 1. He did have the 55t motor and then he went to the 65t. The 55t gave a little more wheel speed but less torque than the 65t. From what I have seen the TXT 1 climb, I would say that either is ok. I suppose its what you feel happy with. Torque or speed. Have you carried out the top ten tips to you TXT 1 ? They do make a big difference Here is the link for you. http://www.rccrawler.com/20txt.htm Last edited by Tronk; 12-31-2006 at 03:50 AM. |
![]() | #8 |
I'm not done yet,But i did not know what motor to go with the 9 Tooth Pinion.65t sounds good.
![]() | #9 |
Powered by Awesome ![]() Join Date: Sep 2004 Location: Parker, Colorado
heres what you gotta do: raise the tranny up chop the chassis plates stretch the wheelbase lock the axles with JB Weld get better rims/tires bring the lower links to the top f the axle i ran a gd600 gear reduction unit and 1 stock can and it worked great 2 high torque servos behind the axle steering setup revo shafts |
