![]() | #1 |
Newbie Join Date: Nov 2006 Location: Renton, WA
My front steering servo won't turn my wheels, I have a HS-645mg and I made a custom 90* bracket around the upper half of the axle so the mount is secure, also my drag link is also very straight, it just flat out won't turn. what could this be?
![]() | #2 |
2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Big Bear Lake
645mgs are good for 2.2 crawlers, but lack the power for a Super rig.
![]() | #3 |
I have an hs-805bb sitting here also, just need to make a new mount
![]() | #4 |
Quarry Creeper Join Date: Feb 2006 Location: Tweaking my shaft
I was running a Hitech 985 in the front. I switched to a 5955 Hitech digital servo. It works alot better, but it still won't turn the wheels if you are applying throttle and turning against an object. The big shafties are hard to turn because all 4 wheels are locked together because of the transmission and drive shafts vs. a Clod where only the 2 wheels on each axle are locked together, and the 2 axles are only electrically connected. Use the strongest servos you can afford/fit on your rig. Good Luck
