| | #1 |
| Rock Stacker Join Date: Feb 2004 Location: Sweden!
| Hey everyone, I noticed that you can reposition the lower links so that they are attached next to the lower cantilever mounts (in one of the four things that sticks out, the outer closest to the chassi)...hard to explain but I hope you get it Is this a good idea? I've already noticed that you need to put some washers on the inner ball-joint otherwise the link will bind on the chassi... The length of the stock link are enough when you remove the plastic washers, mabey a tad (3-4 mm to long)... |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: May 2004 Location: Hartford, Connecticut
| DC, I just made that change on my TXT. I haven't run it yet (going tomorrow), but so far everything looks good. I used MTPA steering servo mounts, and everything clears just fine. No binding at all. Vince |
| | #3 |
| Did you lengthen your upper links? If so how much? |
| | #4 |
| RCC Addict Join Date: Apr 2004 Location: 5280
| All you need to do is move the lower link to the mount directly across from the lower canti mount. If you want to know if it works...look in Get Togethers for May 2nd Boulder Area Crawlin, and look at the pics of my Rig. It works well. No need to space anything. Remove the spacer from the Lower links ball mount, on the axle end, otherwise your pinion angle will be crap. |
| | #5 |
| Pebble Pounder Join Date: Apr 2004
| ive tried it but noticed that it limited articulation, |
| | #6 |
| Did you try putting spacers at the inner mounting points of the lower links? I did (about 2 x 1 mm) and I found that it won't, based upon the amount of shock compression I got... The spelling in this post may vary because I'm drunk ;) However, the opinions, don't |
| | #7 |
| ok il try, and will plastic spacers do?? i have couple of such. And another thing i noticed when doing it is that now links are more parralel is it good?? So what to do, put links on upper mountings, take one spacer of the links, and put another one on the inboard mountings?? anything else?? Thanks ( today or tommorow ill JB welb diffs |
| | #8 |
| Quarry Creeper Join Date: May 2004 Location: portland OR
| no you must lock the diffs, or at least first lock the fron diff and see how you like it. |
| | #9 |
| i locked the diffs |
| | #10 |
| but does repositioning lower links gives more articulation?? or less? Thanks i cant see it, and cant see if it helps :( |
| | #11 |
| If anything it will give better or the same artic...The limit I have are the the tires hits the chassi and that the shocks are bottoming out... (I also have that servo issue but that is just one wheel)... |
| | #12 |
| and maybe cutting the pretruding part that you screw lower link on would help, though im too frighten to do it :( |
| | #13 |
| Pebble Pounder Join Date: Jan 2008 Location: Federal Way
| Don't be scared to cut it off. I did and you know what I found? A hole! Not just any hole but a hole the same size as the other holes inthe part! It ends up looking like the lower one. Cut it off you will be fine |
| | #14 |
| Quarry Creeper Join Date: Aug 2007 Location: liverpool, ny
| ^ i doubt its still a concern after nearly six years!?! |
| | #15 |
| Maybe not to him but it might be for others... |
| Thread Tools | |
| Display Modes | |
