Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Replacement Knuckles
Old 02-12-2005, 10:20 PM   #1
Location: Driving the Troysion Stick up the BIG BOY line!
Default Replacement Knuckles
I broke my first steering knuckle on the txt. Does anyone make machined replacements? If no one makes machined ones, where 's the best place to order new plastic ones ?
cheapjeep2 is offline   Reply With Quote
Old 02-12-2005, 10:35 PM   #2
well you do know that the steering knuckles are the exact same thing as a clod right? My guess would be that towerhobbies would be a great place to get replacements. And if you want aluminum parts goto rc4wd.com but they are expensive
minitrucker is offline   Reply With Quote
Old 02-13-2005, 09:15 AM   #3
I just ordered 2 sets of the alloy knuckles. Well see how they work out. I didn't want the plastic ones again as I broke the knuckle crawling in doors on the couch.
Old 02-13-2005, 10:17 AM   #4
MODERATOR™
EeePee's Avatar
Says in your sig right there, "Hitec HSR-5995TG axle killin' servos. "
EeePee is offline   Reply With Quote
Old 02-13-2005, 11:05 AM   #5
I guess I was right, but I no longer have those servos, need edit the sig.
Old 02-13-2005, 11:53 AM   #6
MODERATOR™
EeePee's Avatar
[Hi jacking]
200:1 with a 55t Lathe motor? That thing slower than slow?
[/Hi jacking]
Old 02-13-2005, 12:49 PM   #7
Originally Posted by EeePee
[Hi jacking]
[/Hi jacking]
It was too slow, but mighty powerful. Gearing with the stock motor was a 129:1, I added the Lathe and I guessed around 200:1. I switched the pinion on the lathe from 12t to 18t to bring it back around 120-129:1 .
Old 02-22-2005, 04:57 PM   #8
Thumbs up
Got the inetrc.com alloy knuckles on. Love them. Better steering response, a little tighter radius, and it just looks cool!.
